set the on-screen widget position programmatically
6074
12
02-24-2017 11:24 AM
LefterisKoumis
I use the _setDesktopPosition function used in the OnScreenWidget.js in my custom widget.js to set the position of a panel at start up but it ignores it.
Ideas?
startup: function () {
html.place(this.domNode, jimuConfig.mapId);
html.setStyle(this.domNode, {
left: 100 + 'px',
right: 'auto',
top: 100 + 'px',
// width: (position.width || this.position.width || this._originalBox.w) + 'px',
// height: (position.height || this.position.height || this._originalBox.h) + 'px'
thank you.
RobertScheitlin__GISP
Lefteris,
  When using the launchpad theme you should use:
      startup: function() {
        this.inherited(arguments);
        var position = {
          relativeTo: map,
          left: 277,
          top: 225,
          width: 300,
          height: 420
        this.getPanel().setPosition(position);‍‍‍‍‍‍‍‍
MarkCooper5
Does anyone know what needs to be done to achieve this in the tab theme?
Thanks
Mark,
  Have you tried the above?
