search fails in enhanced search tool widget
4376
11
06-06-2016 12:59 PM
devarsimajumder2
Robert Scheitlin, GISP
Hello Robert
First of all Thanks for the enhanced search tool. It is a great tool to use. I have used this layer to make certain search layers  through the use of our basemap layers which is pulling from our server. I have added two new layers one being ownership and the other one being utility reports. I have made the search tools yet when we try to search by  record number or owner name the search fails. is there a way you can help me with this? Thank you.
Devarsi
Tags (1)
RobertScheitlin__GISP
Devarsi,
  You have "Ownership Search" in the layers Definition Expression field. If you look at the widgets help document then you will see that this field is not suppose to be any type of label. It is only suppose to be a true SQL expression (if you need/want to define a definition expression).
Devarsi,
  There is not enough information here for me to provide much guidance, Can you attach your config_Enhanced Search.json file for me to look at?
devarsimajumder2
yeah i can do that.. how do you want me to attach it. do you want me to email it to you or post it  here on a thread?
Devarsi,
  I like to maintain all communication on GeoNet.
devarsimajumder2
i pasted the config file below. Thanks for your help in this matter. I appreciate it.
Devarsi,
So the last search layer that allows to search by Account Number or Owner Name, you have that setup where the entered name must equal the data in the ownername filed. Normally you would want to configure this to use the contains operator instead of equals.
devarsimajumder2
Hey robert
still shows that it is failing.. Could it be something with the website itself from where the server is pulling the layer? The other layers are working fine again I have pasted the  config file below thanks for the help
  "layers": [
      "name": "Louisville Zoning",
      "url": "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/M...",
      "definitionexpression": "ZONING_TYPE = 'RESIDENTIAL'",
      "spatialsearchlayer": true,
      "zoomScale": 10000,
      "shareResult": false,
      "addToAttrib": false,
      "expressions": {
        "expression": [
            "alias": "Zoning Type",
            "textsearchlabel": "Search by Zoning Type",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "ZONING_TYPE",
                    "label": "ZONING_TYPE",
                    "shortType": "string",
                    "type": "esriFieldTypeString"
                  "valueObj": {
                    "value": ""
                  "prompt": "Zoning Type is",
                  "textsearchhint": "Example: RESIDENTIAL",
                  "sqltext": "ZONING_TYPE = '[value]'",
                  "operation": "stringOperatorIs",
                  "uniquevalsfromfield": "ZONING_TYPE"
                  "fieldObj": {
                    "name": "ZONING_NAME",
                    "label": "ZONING_NAME",
                  "valueObj": {
                    "value": ""
                  "prompt": "Zoning Name is",
                  "textsearchhint": "Example: RES SINGLE FAMILY",
                  "sqltext": "ZONING_NAME = '[value]'",
                  "uniquevalsfromfield": "ZONING_NAME",
                  "operator": "AND"
      "titlefield": "ZONING_NAME",
      "fields": {
        "all": false,
        "field": [
            "alias": "ZONING_NAME"
            "name": "ZONING_CODE",
            "alias": "ZONING_CODE",
            "popuponly": true
            "alias": "ZONING_TYPE",
            "popuponly": true
      "layersymbolfrom": "config"
      "name": "Traffic Cameras",
      "url": "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_PublicSafety_Louisville/...",
      "definitionexpression": "",
      "zoomScale": 5000,
      "shareResult": true,
      "addToAttrib": true,
      "expressions": {
        "expression": [
            "alias": "Traffic Camera Description",
            "textsearchlabel": "Search Traffic Cameras by Location...",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "DESCRIPTION",
                    "label": "DESCRIPTION",
                  "valueObj": {},
                  "prompt": "DESCRIPTION starts with",
                  "textsearchhint": "Example: I-71",
                  "sqltext": "DESCRIPTION LIKE '[value]%'",
                  "operation": "stringOperatorStartsWith",
                  "userlist": "I-71,I-64"
      "titlefield": "DESCRIPTION",
      "fields": {
        "all": false,
        "field": [
            "alias": "Description"
            "name": "URL",
            "alias": "Show Image",
            "visible": false
            "name": "ONLINE",
            "alias": "Online"
            "name": "LAST_UPDATED",
            "alias": "Last Updated",
            "dateformat": "MM/dd/yyyy",
            "useutc": true,
            "isdate": true
      "links": {
        "link": [
            "alias": "View Traffic Photo",
            "content": "{URL}",
            "icon": "http://resources.arcgis.com/en/help/flex-viewer/live/assets/images/i_camera.png",
            "disablelinksifnull": true,
            "popuptype": "image"
      "layersymbolfrom": "server"
      "name": "Tax Sales",
      "url": "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/AssessorsLiveLayers/MapServer/1",
      "spatialsearchlayer": false,
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "alias": "Deed Type",
            "textsearchlabel": "Search By Deed Type",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "DOCNAME",
                    "label": "Document Name",
                  "valueObj": {
                    "value": ""
                  "prompt": "Document Name is",
                  "textsearchhint": "Choose From List",
                  "sqltext": "DOCNAME = '[value]'",
                  "uniquevalsfromfield": "DOCNAME"
            "alias": "Site Address",
            "textsearchlabel": "Search By Site Address",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "SITEADDRESS",
                    "label": "Full Site Address",
                  "valueObj": {
                    "value": ""
                  "prompt": "Full Site Address contains",
                  "textsearchhint": "1702 Hickory Bark Ln",
                  "sqltext": "Upper(SITEADDRESS) LIKE Upper('%[value]%')",
                  "operation": "stringOperatorContains"
      "titlefield": "PARCELID",
      "fields": {
        "all": false,
        "field": [
            "name": "PARCELID",
            "alias": "Parcel Identification Number"
            "alias": "Full Site Address"
            "name": "DOCNAME",
            "alias": "Document Name"
            "name": "RECORDDT",
            "alias": "Date Recorded",
            "isdate": true
            "name": "TRANSDT",
            "alias": "Transaction Date",
            "isdate": true
            "name": "GRANTOR",
            "alias": "Grantor"
            "name": "GRANTEE",
            "alias": "Grantee"
            "name": "LIBER",
            "alias": "Liber"
            "name": "PAGE",
            "alias": "Page"
            "name": "SALEAMNT",
            "alias": "Sale Amount",
            "isnumber": true
      "links": {
        "link": []
  "initialView": "text",
  "enablePopupsOnResultClick": true,
  "limitsearch2mapextentchecked": false,
  "autozoomtoresults": true,
  "mouseovergraphics": false,
  "toleranceforpointgraphicalselection": 6,
  "bufferDefaults": {
    "addtolegend": false,
    "bufferUnits": {
      "bufferUnit": [
          "name": "UNIT_FOOT",
          "label": "Feet"
          "name": "UNIT_STATUTE_MILE",
          "label": "Miles"
          "name": "UNIT_METER",
          "label": "Meter"
    "bufferDefaultValue": 5,
    "bufferWKID": 102003,
    "simplefillsymbol": {
      "color": [
        1,
        185,
        253,
        128
      "outline": {
        "color": [
          1,
          185,
          253,
          204
        "width": 1,
        "type": "esriSLS",
        "style": "esriSLSSolid"
      "type": "esriSFS",
      "style": "esriSFSSolid"
  "spatialrelationships":{
    "spatialrelationship":[
        "name":"esriSpatialRelContains",
        "label":"entirely contained in"
        "name":"esriSpatialRelIntersects",
        "label":"intersected by"
        "name":"esriSpatialRelEnvelopeIntersects",
        "label":"intersected by envelope of"
  "graphicalsearchoptions":{
    "enablepointselect": true,
    "enablelineselect": true,
    "enablepolylineselect": true,
    "enableextentselect": true,
    "enablecircleselect": true,
    "enablepolyselect": true,
    "showmultigraphicsgraphicaloption": true,
    "showaddtolerancegraphicaloption": true,
    "showaddsqltextgraphicaloption": true,
    "showbuffergraphicaloption": true,
    "buffercheckedbydefaultgraphicaloption": false,
    "multipartgraphicsearchchecked": false,
    "addpointtolerancechecked": false,
    "keepgraphicalsearchenabled": true
  "symbols": {
    "simplemarkersymbol": null,
    "picturemarkersymbol": {
      "url": "images/i_search.png",
      "height": "20",
      "width": "20",
      "type": "esriPMS",
      "angle": "0"
    "simplelinesymbol": {
      "type": "esriSLS",
      "style": "esriSLSSolid",
      "color": [
        255,
        0,
        0,
        204
      "width": 2
      "color": [
        255,
        0,
        0,
        128
      "outline": {
        "color": [
          255,
          0,
          0,
          204
        "width": 2,
        "type": "esriSLS",
      "type": "esriSFS",
devarsimajumder2
  "layers": [
      "name": "Parcels",
      "url": "http://65.123.159.55/arcgis/rest/services/Flexviewers/BaseMap/MapServer/1",
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "alias": "Parcel Search",
            "textsearchlabel": "Parcel Search",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "ExtendedSU",
                    "label": "ExtendedSU",
                  "valueObj": {
                    "value": ""
                  "prompt": "Subdivision",
                  "textsearchhint": "Select a Subdivision or Unit",
                  "sqltext": "ExtendedSU = '[value]'",
                  "uniquevalsfromfield": "ExtendedSU"
                  "fieldObj": {
                    "name": "Block",
                    "label": "Block",
                  "valueObj": {
                    "value": ""
                  "prompt": "Block",
                  "textsearchhint": "Block",
                  "sqltext": "Upper(Block) = Upper('[value]')",
                  "operator": "AND"
                  "fieldObj": {
                    "name": "Lot",
                    "label": "Lot",
                  "valueObj": {
                    "value": ""
                  "prompt": "Lot",
                  "textsearchhint": "Lot",
                  "sqltext": "Upper(Lot) = Upper('[value]')",
                  "operator": "AND"
                  "fieldObj": {
                    "name": "Par",
                    "label": "Par",
                  "valueObj": {
                    "value": ""
                  "prompt": "Par",
                  "textsearchhint": "Par",
                  "sqltext": "Upper(Par) = Upper('[value]')",
                  "operator": "AND"
                  "fieldObj": {
                    "name": "Tr",
                    "label": "Tr",
                  "valueObj": {
                    "value": ""
                  "prompt": "Tract",
                  "textsearchhint": "Tract",
                  "sqltext": "Upper(Tr) = Upper('[value]')",
                  "operator": "AND"
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "name": "WaterServ",
            "alias": "Water Service Provider"
            "name": "SewerServ",
            "alias": "Sewer Service Provider"
            "name": "Feature",
            "alias": "Feature"
            "name": "LegalDesc",
            "alias": "LegalDesc"
            "name": "Subd",
            "alias": "Subd"
            "name": "Block",
            "alias": "Block"
            "name": "Lot",
            "alias": "Lot"
            "name": "Par",
            "alias": "Par"
            "name": "Tr",
            "alias": "Tr"
            "alias": "ExtendedSU"
            "name": "BookPg",
            "alias": "BookPg"
            "name": "Override",
            "alias": "Override"
            "name": "Address",
            "alias": "Address"
            "name": "PreDir",
            "alias": "PreDir"
            "name": "StrName",
            "alias": "StrName"
            "name": "StrSuffix",
            "alias": "StrSuffix"
            "name": "StrDir",
            "alias": "StrDir"
            "name": "StrAddr",
            "alias": "StrAddr"
            "name": "ZipCode",
            "alias": "ZipCode"
            "name": "Acres",
            "alias": "Acres",
            "isnumber": true
            "name": "Alias",
            "alias": "Alias"
            "name": "CoDate",
            "alias": "CoDate",
            "isdate": true
            "name": "PermitDate",
            "alias": "PermitDate",
            "isdate": true
            "name": "PropertyCode",
            "alias": "PropertyCode"
            "name": "LandUse",
            "alias": "LandUse"
            "name": "PropertyName",
            "alias": "PropertyName"
      "links": {
        "link": []
      "orderByFields": [],
      "name": "Subdivisions",
      "url": "http://65.123.159.55/arcgis/rest/services/Flexviewers/publicworksflex/MapServer/37",
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "alias": "Subdivision",
            "textsearchlabel": "Subdivision",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "ExtendedSub",
                    "label": "ExtendedSub",
                  "valueObj": {
                    "value": ""
                  "textsearchhint": "Select a Subdivision",
                  "sqltext": "ExtendedSub = '[value]'",
                  "uniquevalsfromfield": "ExtendedSub"
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "name": "Subd",
            "alias": "Subd"
            "alias": "ExtendedSub"
            "name": "Status2",
            "alias": "Status2"
            "name": "Status1",
            "alias": "Status1"
            "name": "created_user",
            "alias": "created_user"
            "name": "created_date",
            "alias": "created_date",
            "isdate": true
            "name": "last_edited_user",
            "alias": "last_edited_user"
            "name": "last_edited_date",
            "alias": "last_edited_date",
            "isdate": true
            "name": "GlobalID",
            "alias": "GlobalID"
            "name": "Shape_Length",
            "alias": "Shape_Length",
            "isnumber": true
            "name": "Shape_Area",
            "alias": "Shape_Area",
            "isnumber": true
      "links": {
        "link": []
      "name": "City Facilities",
      "url": "http://65.123.159.55/arcgis/rest/services/Flexviewers/publicworksflex/MapServer/2",
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "alias": "City Facilities",
            "textsearchlabel": "City Facilities",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "Name",
                    "label": "Name",
                  "valueObj": {
                    "value": ""
                  "prompt": "Select A Facility",
                  "textsearchhint": "Select A Facility",
                  "sqltext": "Name = '[value]'",
                  "uniquevalsfromfield": "Name"
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "name": "Name",
            "alias": "Name"
            "name": "Address",
            "alias": "Address"
            "isdate": true
            "isdate": true
            "name": "GlobalID",
            "alias": "GlobalID"
      "links": {
        "link": []
      "name": "Record Drawing Asbuilts",
      "url": "http://65.123.159.55/arcgis/rest/services/Flexviewers/publicworksflex/MapServer/7",
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "alias": "Asbuilt",
            "textsearchlabel": "Search for record drawing",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "Title",
                    "label": "Title",
                  "valueObj": {
                    "value": ""
                  "prompt": "Title is",
                  "textsearchhint": "Title is",
                  "sqltext": "Title = '[value]'",
                  "uniquevalsfromfield": "Title"
                  "fieldObj": {
                    "name": "EngineerFirm",
                    "label": "EngineerFirm",
                  "valueObj": {
                    "value": "D"
                  "prompt": "Engineer Firm",
                  "textsearchhint": "Engineer Firm",
                  "sqltext": "EngineerFirm = '[value]'",
                  "uniquevalsfromfield": "EngineerFirm",
                  "operator": "OR"
                  "fieldObj": {
                    "name": "PlanType",
                    "label": "PlanType",
                  "valueObj": {
                    "value": ""
                  "prompt": "Plan Type",
                  "textsearchhint": "Plan Type",
                  "sqltext": "PlanType = '[value]'",
                  "uniquevalsfromfield": "PlanType",
                  "operator": "OR"
                  "fieldObj": {
                    "name": "PlanNumber",
                    "label": "PlanNumber",
                    "shortType": "number",
                    "type": "esriFieldTypeSmallInteger"
                  "valueObj": {
                    "value": null
                  "prompt": "Plan Number",
                  "textsearchhint": "Plan Number",
                  "sqltext": "PlanNumber = [value]",
                  "operation": "numberOperatorIs",
                  "operator": "OR"
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "name": "PlanType",
            "alias": "PlanType"
            "alias": "EngineerFirm"
            "name": "Subdivision",
            "name": "Title",
            "alias": "Title"
            "name": "DateFyComplete",
            "alias": "DateFyComplete",
            "isdate": true
            "name": "DateLastApproval",
            "alias": "DateLastApproval",
            "isdate": true
            "name": "ProjectManager",
            "alias": "ProjectManager"
            "name": "ProjectNumber",
            "alias": "ProjectNumber"
            "name": "UtilityExtension",
            "alias": "UtilityExtension"
            "name": "RecDrawAsbuilt",
            "alias": "RecDrawAsbuilt"
            "name": "TIA",
            "alias": "TIA"
            "name": "DrainageRpt",
            "alias": "DrainageRpt"
            "name": "GeoReport",
            "alias": "GeoReport"
            "name": "ControlNumber",
            "alias": "ControlNumber"
            "name": "Inspector",
            "alias": "Inspector"
            "name": "Inspector2",
            "alias": "Inspector2"
            "name": "Inspector3",
            "alias": "Inspector3"
            "name": "NMDotCN",
            "alias": "NMDotCN"
            "name": "ProjectFiles",
            "alias": "ProjectFiles"
            "name": "ProjFilesDisp",
            "alias": "ProjFilesDisp"
            "alias": "PlanNumber",
            "isnumber": true
            "name": "SHAPE_STArea__",
            "alias": "SHAPE.STArea()",
            "isnumber": true
            "name": "SHAPE_STLength__",
            "alias": "SHAPE.STLength()",
            "isnumber": true
            "name": "Hyperlink",
            "alias": "Hyperlink"
            "name": "Hyperlink2",
            "alias": "Hyperlink2"
            "isdate": true
            "isdate": true
            "name": "GlobalID",
            "alias": "GlobalID"
            "name": "SHAPE_Length",
            "alias": "SHAPE_Length",
            "isnumber": true
            "name": "SHAPE_Area",
            "alias": "SHAPE_Area",
            "isnumber": true
            "name": "ProjectFileLocation",
            "alias": "ProjectFileLocation"
      "links": {
        "link": []
      "name": "Maintenance Connection",
      "url": "http://65.123.159.55/arcgis/rest/services/Flexviewers/publicworksflex/MapServer/4",
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "alias": "Problem:",
            "textsearchlabel": "Problem",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "Problem",
                    "label": "Problem",
                  "valueObj": {
                    "value": ""
                  "prompt": "Select a problem",
                  "textsearchhint": "Select a problem",
                  "sqltext": "Problem = '[value]'",
                  "uniquevalsfromfield": "Problem"
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "name": "WorkOrder",
            "alias": "WorkOrder"
            "name": "AssetName",
            "alias": "AssetName"
            "name": "Location",
            "alias": "Location"
            "name": "Type",
            "alias": "Type"
            "name": "Category",
            "alias": "Category"
            "name": "Priority",
            "alias": "Priority"
            "name": "Repair_Ctr",
            "alias": "Repair_Ctr"
            "name": "Status",
            "alias": "Status"
            "name": "Stat_Date",
            "alias": "Stat_Date"
            "name": "Labor",
            "alias": "Labor"
            "name": "Problem",
            "alias": "Problem"
            "name": "Failure",
            "alias": "Failure"
            "name": "Solution",
            "alias": "Solution"
            "name": "LaborCost",
            "alias": "LaborCost",
            "isnumber": true
            "name": "PartsCost",
            "alias": "PartsCost",
            "isnumber": true
            "name": "TotalCost",
            "alias": "TotalCost",
            "isnumber": true
            "name": "WO_Issued",
            "alias": "WO_Issued"
            "name": "WO_Compl",
            "alias": "WO_Compl"
            "name": "WO_Closed",
            "alias": "WO_Closed"
            "name": "xcoord",
            "alias": "xcoord",
            "isnumber": true
            "name": "ycoord",
            "alias": "ycoord",
            "isnumber": true
      "links": {
        "link": []
      "name": "Traffic Impact Analysis",
      "url": "http://65.123.159.55/arcgis/rest/services/Flexviewers/publicworksflex/MapServer/8",
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "alias": "Traffic Impact Analysis",
            "textsearchlabel": "Traffic Impact Analysis",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "ReportTitle",
                    "label": "ReportTitle",
                  "valueObj": {
                    "value": ""
                  "prompt": "Traffic Impact Analysis",
                  "textsearchhint": "Traffic Impact Analysis",
                  "sqltext": "ReportTitle = '[value]'",
                  "uniquevalsfromfield": "ReportTitle"
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "name": "Id",
            "alias": "Id",
            "isnumber": true
            "name": "AcceptDate",
            "alias": "AcceptDate",
            "isdate": true
            "alias": "ReportTitle"
            "name": "Catalogue",
            "alias": "Catalogue"
            "name": "ReportVersion",
            "alias": "ReportVersion"
            "name": "Shape_STArea__",
            "alias": "Shape.STArea()",
            "isnumber": true
            "name": "Shape_STLength__",
            "alias": "Shape.STLength()",
            "isnumber": true
            "isdate": true
            "isdate": true
            "name": "GlobalID",
            "alias": "GlobalID"
            "isnumber": true
            "isnumber": true
      "links": {
        "link": []
      "name": "Utility Reports",
      "url": "http://65.123.159.55/arcgis/rest/services/Flexviewers/publicworksflex/MapServer/11",
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "alias": "Utility Reports",
            "textsearchlabel": "Utility Reports",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "EngineeringFirm",
                    "label": "EngineeringFirm",
                  "valueObj": {
                    "value": ""
                  "prompt": "Engineering Firm",
                  "textsearchhint": "Engineering Firm",
                  "sqltext": "EngineeringFirm = '[value]'",
                  "uniquevalsfromfield": "EngineeringFirm"
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "alias": "EngineeringFirm"
            "isdate": true
            "name": "CatalogueNumber",
            "alias": "CatalogueNumber"
      "links": {
        "link": []
      "name": "Ownership",
      "url": "http://65.123.159.55/arcgis/rest/services/Flexviewers/BaseMap/MapServer/2",
      "definitionexpression": "Ownership Search",
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "alias": "Ownership Search",
            "textsearchlabel": "Search by Ownership",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "ACCOUNTNUM",
                    "label": "ACCOUNTNUM",
                  "valueObj": {
                    "value": ""
                  "prompt": "Account Number",
                  "textsearchhint": "Account Number",
                  "sqltext": "Upper(ACCOUNTNUM) = Upper('[value]')",
                  "fieldObj": {
                    "name": "OWNERNAME",
                    "label": "OWNERNAME",
                  "valueObj": {
                    "value": ""
                  "prompt": "Owner Name",
                  "textsearchhint": "Owner Name",
                  "sqltext": "Upper(OWNERNAME) = Upper('[value]')",
                  "operator": "OR"
      "titlefield": "Account_No",
      "fields": {
        "all": false,
        "field": [
            "name": "Account_No",
            "alias": "Account_No"
            "name": "Parcel_ID",
            "alias": "Parcel_ID"
            "alias": "OWNERNAME"
            "name": "OWNERADD_1",
            "alias": "OWNERADD_1"
            "name": "SUBDIVISIO",
            "alias": "SUBDIVISIO"
      "links": {
        "link": []
  "exportsearchurlchecked": true,
  "bufferDefaults": {
    "bufferUnits": {
      "bufferUnit": [
          "label": "Feet",
          "name": "UNIT_FOOT"
          "label": "Meter",
          "label": "Miles",
      "color": [
        1,
        185,
        253,
        128
      "outline": {
        "color": [
          1,
          185,
          253,
          204
        "width": 0.75,
        "type": "esriSLS",
      "type": "esriSFS",
    "addtolegend": true
  "spatialrelationships": {
    "spatialrelationship": [
        "label": "entirely contained in",
        "name": "esriSpatialRelContains"
        "label": "intersected by",
        "name": "esriSpatialRelIntersects"
        "label": "intersected by envelope of",
        "name": "esriSpatialRelEnvelopeIntersects"
  "graphicalsearchoptions": {
    "keepgraphicalsearchenabled": false
  "symbols": {
      "angle": 0,
      "xoffset": 0,
      "yoffset": 0,
      "type": "esriPMS",
      "url": "http://localhost:3344/webappbuilder/apps/6/widgets/eSearch/http://localhost:3344/webappbuilder/apps/...",
      "width": 20.00025,
      "height": 20.00025
      "color": [
        255,
        0,
        0,
        204
      "width": 2.25,
      "type": "esriSLS",
      "color": [
        242,
        247,
        233,
        128
      "outline": {
        "color": [
          255,
          0,
          0,
          204
        "width": 1.5,
        "type": "esriSLS",
      "type": "esriSFS",
devarsimajumder2
here is the updated config file for the esearch tool sorry pasted the wrong config file
  "layers": [
      "name": "Parcels",
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "values": {
              "value": [
                  "fieldObj": {
                  "valueObj": {
                    "value": ""
                  "fieldObj": {
                    "name": "Block",
                    "label": "Block",
                  "valueObj": {
                    "value": ""
                  "prompt": "Block",
                  "operator": "AND"
                  "fieldObj": {
                    "name": "Lot",
                    "label": "Lot",
                  "valueObj": {
                    "value": ""
                  "prompt": "Lot",
                  "operator": "AND"
                  "fieldObj": {
                    "name": "Par",
                    "label": "Par",
                  "valueObj": {
                    "value": ""
                  "prompt": "Par",
                  "operator": "AND"
                  "fieldObj": {
                    "name": "Tr",
                    "label": "Tr",
                  "valueObj": {
                    "value": ""
                  "prompt": "Tract",
                  "operator": "AND"
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "name": "Feature",
            "alias": "Feature"
            "name": "Subd",
            "alias": "Subd"
            "name": "Block",
            "alias": "Block"
            "name": "Lot",
            "alias": "Lot"
            "name": "Par",
            "alias": "Par"
            "name": "Tr",
            "alias": "Tr"
            "name": "BookPg",
            "alias": "BookPg"
            "name": "Override",
            "alias": "Override"
            "name": "Address",
            "alias": "Address"
            "name": "PreDir",
            "alias": "PreDir"
            "name": "StrName",
            "alias": "StrName"
            "name": "StrDir",
            "alias": "StrDir"
            "name": "StrAddr",
            "alias": "StrAddr"
            "name": "ZipCode",
            "alias": "ZipCode"
            "name": "Acres",
            "alias": "Acres",
            "isnumber": true
            "name": "Alias",
            "alias": "Alias"
            "name": "CoDate",
            "alias": "CoDate",
            "isdate": true
            "isdate": true
            "name": "LandUse",
            "alias": "LandUse"
      "links": {
        "link": []
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "values": {
              "value": [
                  "fieldObj": {
                  "valueObj": {
                    "value": ""
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "name": "Subd",
            "alias": "Subd"
            "name": "Status2",
            "alias": "Status2"
            "name": "Status1",
            "alias": "Status1"
            "isdate": true
            "isdate": true
            "name": "GlobalID",
            "alias": "GlobalID"
            "isnumber": true
            "isnumber": true
      "links": {
        "link": []
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "Name",
                    "label": "Name",
                  "valueObj": {
                    "value": ""
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "name": "Name",
            "alias": "Name"
            "name": "Address",
            "alias": "Address"
            "isdate": true
            "isdate": true
            "name": "GlobalID",
            "alias": "GlobalID"
      "links": {
        "link": []
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "alias": "Asbuilt",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "Title",
                    "label": "Title",
                  "valueObj": {
                    "value": ""
                  "fieldObj": {
                  "valueObj": {
                    "value": "D"
                  "operator": "OR"
                  "fieldObj": {
                    "name": "PlanType",
                  "valueObj": {
                    "value": ""
                  "operator": "OR"
                  "fieldObj": {
                  "valueObj": {
                    "value": null
                  "operator": "OR"
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "name": "PlanType",
            "alias": "PlanType"
            "name": "Title",
            "alias": "Title"
            "isdate": true
            "isdate": true
            "name": "TIA",
            "alias": "TIA"
            "name": "NMDotCN",
            "alias": "NMDotCN"
            "isnumber": true
            "isnumber": true
            "isnumber": true
            "isdate": true
            "isdate": true
            "name": "GlobalID",
            "alias": "GlobalID"
            "isnumber": true
            "isnumber": true
      "links": {
        "link": []
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "Problem",
                    "label": "Problem",
                  "valueObj": {
                    "value": ""
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "name": "Location",
            "alias": "Location"
            "name": "Type",
            "alias": "Type"
            "name": "Category",
            "alias": "Category"
            "name": "Priority",
            "alias": "Priority"
            "name": "Status",
            "alias": "Status"
            "name": "Labor",
            "alias": "Labor"
            "name": "Problem",
            "alias": "Problem"
            "name": "Failure",
            "alias": "Failure"
            "name": "Solution",
            "alias": "Solution"
            "isnumber": true
            "isnumber": true
            "isnumber": true
            "name": "WO_Compl",
            "alias": "WO_Compl"
            "name": "xcoord",
            "alias": "xcoord",
            "isnumber": true
            "name": "ycoord",
            "alias": "ycoord",
            "isnumber": true
      "links": {
        "link": []
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "values": {
              "value": [
                  "fieldObj": {
                  "valueObj": {
                    "value": ""
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "name": "Id",
            "alias": "Id",
            "isnumber": true
            "isdate": true
            "isnumber": true
            "isnumber": true
            "isdate": true
            "isdate": true
            "name": "GlobalID",
            "alias": "GlobalID"
            "isnumber": true
            "isnumber": true
      "links": {
        "link": []
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "values": {
              "value": [
                  "fieldObj": {
                  "valueObj": {
                    "value": ""
      "titlefield": null,
      "fields": {
        "all": false,
        "field": [
            "isdate": true
      "links": {
        "link": []
      "zoomScale": 10000,
      "expressions": {
        "expression": [
            "values": {
              "value": [
                  "fieldObj": {
                  "valueObj": {
                    "value": ""
                  "prompt": "ACCOUNTNUM contains",
                  "sqltext": "Upper(ACCOUNTNUM) LIKE Upper('%[value]%')",
                  "fieldObj": {
                  "valueObj": {
                    "value": ""
                  "prompt": "OWNERNAME contains",
                  "sqltext": "Upper(OWNERNAME) LIKE Upper('%[value]%')",
                  "operation": "stringOperatorContains",
                  "operator": "OR"
      "fields": {
        "all": false,
        "field": [
      "links": {
        "link": []
  "bufferDefaults": {
    "bufferUnits": {
      "bufferUnit": [
          "label": "Feet",
          "name": "UNIT_FOOT"
          "label": "Meter",
          "label": "Miles",
      "color": [
        1,
        185,
        253,
        128
      "outline": {
        "color": [
          1,
          185,
          253,
          204
        "width": 0.75,
        "type": "esriSLS",
      "type": "esriSFS",
    "addtolegend": true
  "symbols": {
      "angle": 0,
      "xoffset": 0,
      "yoffset": 0,
      "type": "esriPMS",
      "width": 20.00025,
      "height": 20.00025
      "color": [
        255,
        0,
        0,
        204
      "width": 2.25,
      "type": "esriSLS",
      "color": [
        242,
        247,
        233,
        128
      "outline": {
        "color": [
          255,
          0,
          0,
          204
        "width": 1.5,
        "type": "esriSLS",
      "type": "esriSFS",
Devarsi,
