Scroll a list when clicking a graphic
3525
10-30-2015 04:54 PM
SebastianRoberts
I'm using Robert's eSearch Widget.  If the widget is maximized, I'd like the user to be able to click (or touch) a graphic and have the result list in the widget scroll to the record (or list item) that corresponds to the graphic.  Has anyone done anything similar with scrolling a list in the WAB that might get me started?
RobertScheitlin__GISP
Sebastian,
  Great Idea. I will add this in the next release.Here are the needed changes:
Widget,js (lines 6-10)
      _searchResultListByOID: function (OID) {
        for (var i = 0; i < this.list.items.length; i++) {
          var item = this.list.items;
          var point = item.centerpoint;
          if (item.OID === OID) {
            var itemDom = dojo.byId("uniqname_0_1" + item.id);
            if(itemDom){
              itemDom.scrollIntoView(false);
            this.list.setSelectedItem("uniqname_0_1" + item.id);
            if (this.map.infoWindow && this.config.enablePopupsOnResultClick) {
              this.map.infoWindow.setFeatures([item.graphic]);
              if (this.map.infoWindow.reposition) {
                this.map.infoWindow.reposition();
              this.map.infoWindow.show(point);
List.js (add this new function)
      setSelectedItem: function(id) {
        var item = this._getItemById(id);
        if (!item) {
          return;
        domClass.replace(id, this._itemSelectedCSS, ((item.alt) ? this._itemAltCSS:this._itemCSS));
        if (this._selectedNode) {
          domClass.replace(this._selectedNode, ((item.alt)? this._itemAltCSS:this._itemCSS), this._itemSelectedCSS);
        this._selectedNode = id;
Sebastian,
            if(itemDom){
        if (!item) {
          return;
SebastianRoberts
Robert,
  Works splendidly.  Once again you've saved me a good number of hours!
SebastianRoberts
One minor change.  In Robert's sample code, replace the two instances of:
"uniqname_0_1"
with:
this.list.id.toLowerCase()
I found that if you have more than one widget that uses a list, then depending on which widget is created first, the unique name may be "uniqname_0_1" or "uniqname_0_2" for the list.
