Robert's eSearch Widget: where is "The value entered in not valid" defined.
1648
09-23-2019 04:53 PM
BingJing
Hi All
I am trying to modify the eSearch Widget for our needs.
Please see attached screen photo. I want to allow address or APN that are not in the drop down list so that I can show a redirect message to link to google map.. Where is the string "The value entered in not valid"  defined?
Thank you in advance.
RobertScheitlin__GISP
Bing,
   That is an internal dojo dijit validation error string from the dojo library.
It appears when I call this.stringCodedValuesFS.validate().
Bing,
BingJing
Hi Robert, Thank you again for the hint.
I am trying to figure out how to allow people entering an address that is not on the auto-complete drop-down. Currently, when a wrong address is entered, the code stops at this function and did not go anywhere.
buildWhereClause: function (layerIndex, expressIndex, /* optional */theValue)
Bing,
   So in the SingleParameter.js find this code block and change it to do something else.
if (!this.stringCodedValuesFS.validate()) {
    //this._showValidationErrorTip(this.stringCodedValuesFS);
    //return null;
    //add your own code here to handle an invalid entry.
BingJing
It took me a lot of debugging.
I commented out the whole section as you put above. Also I commented out this function.
_showValidationErrorTip: function (_dijit) {
if (!_dijit.validate() && _dijit.domNode) {
if (_dijit.focusNode) {
_dijit.focusNode.focus();
_dijit.focusNode.blur();
One last question here, how to get the value of the "wrong address" that user entered here?
This may be against the nature of your design. I am trying to let the user only enter a valid address, but in case they enter a non-existing address, we want to redirect them to a geocoding service to find the area.
Thank you Robert.
BingJing
I think I got it. The below call works.
this.stringCodedValuesFS.attr('displayedValue')
