Removing default widgets from Builder
584
10-01-2020 07:02 AM
TyroneLigon1
Our portal is on an intranet, so some of the default Esri widgets will not work in our environment. I know we can remove those widgets from Builder by editing the list.json file. If I edit the file, will I have unintended consequences (broken applications, for example) if a web app references one of the widgets that has been removed from the list?
