Remove thousand seperator in query widget?
2084
05-03-2017 06:04 AM
KateGormley1
I am currently developing an app using the Web App Builder and am just configuring the query widget.  One of the results I want to display is Year of Survey - but the default settings in the widget bring back the year result with a thousand separator.  Does anyone know how I can remove it?  I can seem to see a remove option in the builder (like you would see in the map viewer).
Thanks
RobertScheitlin__GISP
Kate,
  There is no widget settings to allow for this using the settings UI. But you can manually make the change in the config_Query.json file for your app.
[install dir]\server\apps\[app#]\configs\Query\config_Query.json
Find the field you are wanting the separator removed from and change the format > digitSeparator to false.
Kate,
KateGormley1
Brilliant - thanks, that worked perfectly!
Kate,
   Don't forget to mark this question as answered.
