Joe,
It sounds like you made a code change or css change in the stemApp directory which will affect EVERY new app you create.
What have you added to the widget that is wider and longer than the pane?
Nothing. I have played around with the code and probably altered the scrollbar option but cant seem to revert back to original.
Mark,
As Ken was mentioning the only reason for there to be scrollbars there is the fact that there is something in the widget.html or the code that has been altered to make the DOM think it needs scrollbars. What does the Widget.html look like?
Widget.html for the panel (which is actually the about widget) looks as follows:
<div>
<div class="about-envelope" data-dojo-attach-point="envelopeNode">
<div class="about-container" data-dojo-attach-point="splashContainerNode">
<div class="about-content" data-dojo-attach-point="customContentNode"></div>
</div>
</div>
</div>
OK,
If it is actually the splash widget then what does the apps/[app#]/configs/Splash/config_widgets_Splash_Widget_##.json look like?
"splash": {
"splashContent": "<div align=\"center\"><br /><div align=\"center\"><span style=\"color: rgb(0, 0, 1);\"><img id=\"img_1515077137350\" src=\"data:image/png;base64,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.....
and it goes on for awhile with "amp;"
Mark,
Try opening the splash widgets setting and deleting everything and saving app.
Just to be clear, you are referring to the user text I have typed for the widget within WAB? And this is the About widget not the splash page
