Remove scroll bar option in WAB widget
6961
21
07-20-2018 06:45 AM
joerodmey
How to remove the scroll bars in a widget in WAB?
RobertScheitlin__GISP
OK the about widget then. Open it's setting dialog and delete everything in the textbox area.
MarkLache1
No change. Scrollbars still present
Mark,
   Can you use the advanced editor and attach your about widgets json file from the apps configs folder (you'll have to zip it first)?
joerodmey
json file has been attached
Joe,
  So this is what the about widget looks like in one of my unmodified apps using your json you provided:
joerodmey
I have reverted my code back to original as it was modified to hard code the size in. Something still seems off though. I've even replicated the issue in a brand new app in WAB
Joe,
   It sounds like you made a code change or css change in the stemApp directory which will affect EVERY new app you create.
joerodmey
How can I fix that?
Download WAB again and replace the the contents of the stemApp folder with the stemApp folder from your fresh download.
joerodmey
by stemApp folder do you mean: C:\x\x\x\arcgis-web-appbuilder-2.8\WebAppBuilderForArcGIS\client\stemapp\widgets\About
