Publish data from search widget to eSearch widget
851
11-03-2017 09:23 AM
ZhujingXia
Hi Robert,
I used your eSearch widget for a while now. I'd like to see how to pass the search result from the search widget to your eSearch widget and do the by spatial to intersected with another feature layer.
I put this code in the Startup:Function
 this.fetchDataByName('Search');
and  this code in the onReceiveData:Funtion()
console.log(data.searchResults)
But it does not work. Could you let me know how to pass the search result to your widget?
Thanks
RobertScheitlin__GISP
Zhujing,
   The eSearch is already setup to listen for all publishData events. So all you have to do is add code to the existing onReceiveData function in the eSearch widget to deal with what ever it is you are trying to get from the search widget.
      onReceiveData: function(name, widgetId, data) {
        if(name === 'Search' && data.searchResults){
          //do something with data.searchResults
          console.info(data.searchResults);
