Promoting search layers
3451
6
01-20-2016 01:39 PM
KinleyWinchester
Hey Robert.. I have attached the config.js file that is under widgets folder for my newly created app. I have been working with ESRI products since the mid 90s, but I am new to the development side.  So most of this is a little more clear than if it were written in Greek.
RobertScheitlin__GISP
Kinley,
   I never expected anyone to not define an expression for a search layer so this is definitely the issue. I need to look into how I want to handle this for future releases.
Kinley,
   Sorry I should have gave more specific instructions. When you configure a widget the changes are placed in the apps configs folder and then the widget name.
[install dir]\server\apps\[app#]\configs\eSearch\config_Enhanced Search.json
KinleyWinchester
Ah... ok. Sorry I did a search but I may have been just under the Widget folder, not the app folder.  I will check into this first thing tomorrow and get back with you.
Thanks for your time!
KinleyWinchester
Morning Robert,
I have the attached the config_Enhanced Search file.  I thought this morning that the problem may be that I do not have any attribute query setup, only the shape selection.  I will setup that up now and see it that helps.
Kinley
Kinley,
KinleyWinchester
I am usually the one to do the unexpected.   Thanks for your time.
Kinley,
    Thanks, because you made me aware of this the next version 1.3.0.2 will now support this ability to have no expressions defined for a layer. If all the layer you add to the widget are void of expressions then the "By Value" tab will automatically be removed from the widget.
