Problems with eSearch 3.3 and 3.3.1 for Web AppBuilder
1314
12-05-2014 10:51 AM
MaxMasters
I'm having a couple issues with the Web AppBuilder eSearch 3.3 and 3.3.1 widgets.  Both versions are currently giving me a "Search Failed!" message.
I'm including a couple of video/screenshots that illustrate what is happening.  A previous version of the eSearch widget worked well earlier in the week.  Also the layer i am trying to search: http://gis.goshencounty.org/webadaptor/rest/services/GoshenWAB/MapServer/3 is able to be queried using the Query widget in Beta 3.
Version 3.3 the unique value list populates with the drop down, but gives me a "Search Failed!" error. http://screencast.com/t/evd7hYy3
Version 3.3.1 the unique value list will not populate, and if I type in a value I get the "Search Failed!" error. http://screencast.com/t/2XwctnINmsku
Thanks for the help!
Max
Web AppBuilder Beta 3
RobertScheitlin__GISP
Max,
   Why are you putting "test" in the definition expression box?.. That is not a valid SQL statement for a definition Query.
Max,
MaxMasters
I can't BELIEVE I did that.  Thanks for taking the time to look at that.  WOW.
