Popup Panel widget using selected features
851
03-03-2019 08:58 PM
IanHamilton2
H iRobert, I would be interested in knowing your thought on the following.
I would like to create similar functionality to the Popup Panel widget but instead using selected features from a single layer. The feature info would then be displayed in html format, attributes and attachments.
Is the Popup Panel widget you have created a good starting point?
I am coming from a starting point of having a python script that returns a dynamic html page which I have been serving directly. I was going to create a geoprocessing service which would return html content and display this as output (if this is possible)? but then I noticed your Popup Panel Widget.
Alternatively, if there are other widgets that can display html, I could perhaps start from there?
Obviously, I need a bit of high level direction.
Many thanks for any help,
Ian
RobertScheitlin__GISP
Ian,
  No the popup panel is not really a good fit for a starting point. Based on what you are trying to do I would start with the SampleWidgets Demo widget and add a ContentPane to the widget.html. A ContentPane will render html content well.
dijit/layout/ContentPane — The Dojo Toolkit - Reference Guide
