Popup Panel Widget Customization
8917
23
04-21-2016 07:15 AM
NatashaManzuiga
Hi all,
I'm trying to set a different behavior of the Popup Panel Widget on map click for each layer.
For a particular layer, I need to retrieve data from a webservice passing a field value as parameter.
Is it right what I'm trying to do or you think I have to move this code somewhere else?
at the moment the line 10 gave me an error:
TypeError: this.own is not a function
startup: function () {
    this.inherited(arguments);
    var map = this.map;
    LayerInfos.getInstance(map, map.itemInfo).then(lang.hitch(function(operLayerInfos) {
    operLayerInfos.getLayerInfoArray().forEach(function(layerInfo) {
            if (layerInfo.title == 'Map') {
                var layerId = layerInfo.id;
                console.log('layer ID = ', layerId);
                var layer = map.getLayer(layerId);
                this.own(on(layer, "click", lang.hitch(this, this.onMapClick)));
    this.displayPopupContent(this.popup.getSelectedFeature());
onMapClick: function(event) {
//I want to disable the normal behavior of the click (retrieve data and populate the Popup Panel widget with my customized content)
  var queryTask = new QueryTask('*Service URL*');
  var query = new Query();
  query.returnGeometry = true;
  query.outFields = ['*'];
  query.geometry = event.mapPoint;
  queryTask.execute(query, lang.hitch(this, this.showResults));
showResults: function(results) {
  var resultItems = [];
  var resultCount = results.features.length;
  for (var i = 0; i < resultCount; i++) {
      var featureAttributes = results.features.attributes;
      var URL = "theWebServiceUrl" + featureAttributes.NAME;
    //and I want to pass this URL to call it with through esri/request and retrieve data and then populate the PopUp Panel
Naty
Tags (1)
RobertScheitlin__GISP
Naty,
  The search Widget adds the search result to the maps graphics layer and thus does not have a layer property.
Here is what I think you should do:
this.own(on(this.popup, "selection-change", lang.hitch(this, function () {
          var gra = this.popup.getSelectedFeature();
          if(gra){
            console.info(gra);
            var layer = gra.getLayer();
            if(layer && layer.name === "map"){
              console.info(layer.name);
              var URL = "theWebServiceUrl" + gra.attributes.NAME;
              console.info(URL);
              //this will prevent it from going to the function that displays the popup info
              return;
            }else if(gra.attributes.hasOwnProperty("yourspecificfieldname")){
              var URL2 = "theWebServiceUrl" + gra.attributes.NAME;
              console.info(URL2);
              return;
On line 12 you will have to determine if this is a search result graphic and if so is it one you are interested in. The problem is you are using such a common field name "NAME" so many graphics beside your specific layer use that field name.
Naty,
  That is because line 10 is inside a function that is not scoped:
See line 6 and 13
     //I don't understand why people add a local var for map when they have access to the map using this.map...
    //var map = this.map;
    LayerInfos.getInstance(this.map, this.map.itemInfo).then(lang.hitch(function(operLayerInfos) {
    operLayerInfos.getLayerInfoArray().forEach(lang.hitch(this, function(layerInfo) {
NatashaManzuiga
Robert, I made changes and I removed local var "map"
   var layer;
            layer = this.map.getLayer(layerId);
It runs without error but onMapClick doesnt run when I click on the map..
I tried to log something:
console.log("onMapClick runs");
but nothing happened...
Naty
Naty,
  Have you tried a console.info(layer); to be sure that you sound the layer?
NatashaManzuiga
Robert, I tried with this code:
        var layer,layerId;
console write all the info of the layer...but...nothing happens on onMapClick event...
Naty
Naty,
  Well I should have asked if that layer is a sublayer of a dynamic map service or is it an actual featurelayer?
NatashaManzuiga
i has sublayers and i need to use this popup in one of them.
thanks,
Naty
Naty,
  Then I was wrong you do need to switch back to the map on click instead of the layer as then is nothing to fire a click event for when using a dynamic map service.
NatashaManzuiga
Robert thanks for your patience with me..
So, what can I do? I can change my Services, too...
Naty
Naty,
Re-evaluating what your goal is this is actually much simpler than you road we started down. Update this portion of the Widget.js:
          if(layer.name === "map"){
            return;
