PopUp displaying link to related records
2674
08-07-2018 01:39 PM
JaysonLindahl
Is there a way to display a link to the related records directly in the popup information, similar to the way it works in the portal map?
deleted-user-qpvAI3Fo0MKR
Yep. Just check this box when Configuring Popup:
Results:
Results:
JaysonLindahl
Not sure where that configuration is.  Is that the latest version of AGOL?  We are using AGOL internally, at version 10.5.1.
RobertScheitlin__GISP
Jayson,
   That is the AGOL Map Viewer app when you configure your layers popups.
