Open a widget in its own panel (dialog)
7083
10
06-05-2016 06:06 AM
Haider_Ali
I have added a button on it's click i want to open a widget as a dialog. i am using below code to open a widget
var wconfig =
            "name": "Draw",
            "label": "Draw",
            "version": "2.0.1",
            "uri": "widgets/Draw/Widget",
            "config": "configs/Draw/config_Draw.json",
            "index": 6,
            "id": "widgets_Draw_Widget"
this.widgetManager.loadWidget(wconfig).then(lang.hitch(this, function(widget) {
            widget.startup();
            this.widgetManager.openWidget(widget);
In the console it says widget [widgets/Draw/Widget] created. but i can't see the widget.
If i use this._getPanel(wconfig,true) the widget display in left panel
_getPanel: function(widgetCfg, start) {
   var def = new Deferred();
   var panel;
   if (widgetCfg) {
  // Try getting the panel for this widget
  panel = registry.byId(widgetCfg.id + '_panel');
  if (panel) {
   def.resolve(panel);
  } else {
   this.panelManager.showPanel(widgetCfg).then(function(panel) {
  if (start) {
   panel.startup();
  def.resolve(panel);
   } else {
  def.resolve(undefined);
   return def;
Any Idea what i am doing wrong here
Haider_Ali
sorry for not mentioning screen size   before thanks
