onOpen Multiple Widgets: Dart Theme
3325
10
02-26-2018 07:02 AM
JamesCrandall
WAB Developer 2.5
Dart Theme
Attempting to open two widgets at application open.
-Popup Panel Widget
-Edit Widget
I updated the config.json of each widets openAtStart property but this doesn't work to open both at the same time.  Not sure if there's another palce(s) that will need altered.
  "widgetPool": {
    "panel": {
      "uri": "themes/DartTheme/panels/DartPanel/Panel",
      "position": {
        "relativeTo": "map"
    "widgets": [
        "uri": "widgets/LayerList/Widget",
        "version": "2.5",
        "id": "widgets_LayerList_Widget_19",
        "name": "LayerList",
        "index": 2
        "name": "Edit",
        "version": "2.5",
        "uri": "widgets/Edit/Widget",
        "index": 3,
        "id": "widgets_Edit_Widget_54",
        "config": "configs/Edit/config_Edit.json",
        "openAtStart": true
        "name": "PopupPanel",
        "uri": "widgets/PopupPanel/Widget",
        "config": "configs/PopupPanel/config_PopupPanel.json",
        "index": 4,
        "id": "widgets_PopupPanel_Widget_55",
        "version": "2.6",
        "openAtStart": true
JamesCrandall
Oh totally my fault! I was so buried in the JavaScript that I was certain I broke it somehow.  I had to remove/re-add the original widget to ultimately see that config!!! LOL.
