NumberTextBox glitch?
2398
10-15-2015 09:39 AM
LefterisKoumis
I created a coordinate widget that has two text boxes to accept the long and lat from the user.
I used the dijit/form/NumberTextBox.
At first, I didn't use any constraints but it seems it would not display any numbers with more than 3 decimal places!
Then, I introduced the constraints and specify decimal places.
With the constrainsts, the NumberTextBox will display more than 3 decimal places but it prompts that this is not a numeric value!!!
What am I doing wrong?
Thanks.
<input id="longitude" type="text"
    data-dojo-type="dijit/form/NumberTextBox"
    name= "long"
    required="true"
    value=""
    data-dojo-props="constraints:{min:-900000000000,max:900000000000,places:10}, invalidMessage:'Please enter a numeric value.'" />
RobertScheitlin__GISP
Lefteris,
  Here is what I use in my eSearch widget for numeric entry:
<input data-dojo-attach-point="numberTextBox" data-dojo-type="dijit/form/NumberTextBox"
                     data-dojo-props="intermediateChanges:true,constraints: {pattern: '#####0.##########'}"
                     class="dijit-form-NumberTextBox" style="display:none;width:100%;height:30px;" />
Lefteris,
LefterisKoumis
Thank you. I used the pattern and it works. I will mark this as answered but the dojo documentation should list any limitations with the NumberTextBox.
