New to GeoNet and Custom Widgets.
3264
02-16-2016 07:42 AM
ScottShenberger
Can someone recommend some online resources for a person new to web appbuilder and custom widgets? We are trying to create a widget that will calculate water pressure based on an onclick event that would pull in a value from an existing polygon and a value from a DEM.
Thanks
Scott Shenberger
Tucson Water
RobertScheitlin__GISP
ScottShenberger
Robert
Thank you for the quick response
Scott
RebeccaStrauch__GISP
And my blog (messy and long) for links to the currently available custom widgets (including many from Robert)
Web AppBuilder Developer Edition - Customization Resource List
Usually helps to look at what others have done.
DerekLaw
Esri Esteemed Contributor
Hi Scott,
You may also want to watch these 2 videos from the Esri 2014 Developer Summit:
Hope this helps,
