NearMe Widget 2.5 - Direction Print ESRI Layout
1223
10-26-2017 08:37 PM
RodWoodfordOld
Hi
Is it possible to modify the default Directions Print Layout. I would like to change the ESRI logo and ESRI footer comments.
cheers
Rod
Tags (1)
RobertScheitlin__GISP
Rod,
  There is now way I am aware of to change the template. The API is hard coded to use what it is using. I have looked into this already.
RodWoodfordOld
Thanks Robert, I couldn't find any other post on this. It's a shame its hardcoded, but can understand the reasoning. Do you know if you can turn off the printing function at all?
cheers
Rod,
   I would use a css rule to hide the print button then.
