Move form over the panel in Jewelry box theme
3022
05-04-2016 11:47 AM
SebastienPelletier
I develop with the web appbuilder developer and I use the theme Jewelry box.
I wonder if there a way to move a form (example: Mesasure wiget) over the left panel. By default the form is moving under and is hidden by the panel.
Thanx
RobertScheitlin__GISP
Sebastien,
  This may have other adverse effect I have not seen but here is some simple css to fix that:
.map{
  overflow: visible !important;
Just add it to the common.css for your server\apps\[app#]\themes\JewelryBoxTheme
Sebastien,
.map{
SebastienPelletier
Thank you Robert , this solution works and very easy to do . But there is a gap with the edge of the application because it is impossible to move a form to the edge (see image).
Sebastien,
  Yep I can not seem to get past that limit either.
SebastienPelletier
I found , you must change all the calls to : "this.makeMoveable " method in the file jimu.js \ OnScreenWidgetPanel.js
and change the value 0.25 to the desired value
Sebastien,
  Glad you got it working. Don't forget to mark this thread as answered by clicking on the "Correct Answer" link on the thread that answered your question.
