Modifying Group Filter Widget value ordering
540
01-11-2019 11:33 AM
MarkEastwood
Hello,
I am creating an app using v2.10 of WAB. I have added the group filter widget with the following configuration settings.
The Pre-Work Number field has a Long Int data type with a domain value applied to it. The domain values are for example...
Code    Description
3          Test3
2          Test2
1          Test1
When I use the editor widget to set the Pre-work Number value the drop down appears like...
Test3
Test2
Test1
But when I use the Group Filter Widget the values appear ...
Test1
Test2
Test3
Is there anyway of reversing the order of how these values appear in the Group Filter widget?
Thanks in advance!
