Modify a webmap's InfoWindow with javascript in WAB
6664
12
08-05-2020 07:36 AM
DávidGregor
I made a custom popup for a specific layer. But my method is really not good for Web Appbuilder/WebMap environment.
Section from the customPopup widget:
      map = new Map("map", {
        infoWindow: infoWindow,
      //create a popup to replace the map's info window
      var infoWindow = new InfoWindow({
        domNode: domConstruct.create("div"nulldom.byId("map")),
      var popupTemplate = new InfoTemplate();
      popupTemplate.setContent(_getTextContent);
      var featureLayer = new FeatureLayer(substationURL, {
        mode: FeatureLayer.MODE_SNAPSHOT,
        infoTemplate: popupTemplate,
        outFields: ["*"],
      this.map.addLayer(featureLayer);
  featureLayer.on('load'lang.hitch(thisfunction() {
          console.log("load");
          LayerInfos.getInstance(this.mapthis.map.itemInfo).then(lang.hitch(thisfunction(layerInfos) {
            var featureLayerInfo = layerInfos.getLayerInfoById(featureLayer.id);
            featureLayerInfo.title = 'Title';
This way, i have to remove the layer from the webmap to avoid duplication.
I would rather modify programmatically the original layer's infoWindow. But i cannot find any documentation for this.
How can i reference existing objects? Every tutorial or sample creates new ones...
I tought something like this will work:
      this.layerStructure = LayerStructure.getInstance();
      var featureLayer = this.layerStructure.getNodeById(subLayerID);
      featureLayer.infoWindow = popupTemplate
DávidGregor
Thank you so much! It was not working because the infotemplate is infoTemplate  But finally we (you two) solved the case here
Just for the record:
      function getWebmapOperationalLayerById (layerId) {
        var instance = LayerInfos.getInstanceSync();
        var layerFound = null;
        instance.traversalLayerInfosOfWebmap(function (aLayer) {
            if (aLayer.id === layerId) {
                layerFound = aLayer;
                console.log("found")
                return//get out of traversalLayerInfosOfWebmap()
        return layerFound;
      var layerId = 'LayerID';
      var operationalLayer = getWebmapOperationalLayerById(layerId);
      console.log(operationalLayer)
      operationalLayer.getLayerObject().then(function(layerObject){
        var title = 'Popup title';
        var content = 'Custom description. You can use HTML here. <br> And access attribute value like this ${SOME_ATRIBUTE}';
        var sublayerId = 0;
        if(!layerObject.infotemplates){
          layerObject.infoTemplates = {};
        layerObject.infoTemplates[sublayerId]= {
        infoTemplate: new InfoTemplate(titlecontent)
DávidGregor
Do you have any tricks here to leave the related records section untouched when i'm resetting the infotemplate object?
DávidGregor
I could use the PopupManager.js's methods to call the RelatedRecordsPopupProjector.js after the new infotemplate creation. Just it's needed to add the esriViewPopup class to the popup div.
