Map.graphics.clear cannot read property clear of undefined
1193
01-12-2021 04:26 AM
Nadir_Hussain
Dear All,
i am trying to make my first custom widget in web app builder.below is my code.after querying from my feature layer i want to make a graphic and zoom to that feature.my query work and return one feature.But when i want to make a graphic and add this graphic on map.it throws error.my custom widget code is given below.
define(['dojo/_base/declare','jimu/BaseWidget',"esri/tasks/query", "esri/tasks/QueryTask",
"esri/geometry/Polygon","esri/geometry/Extent","esri/symbols/SimpleFillSymbol",'esri/layers/GraphicsLayer',
"esri/SpatialReference","esri/symbols/SimpleLineSymbol","esri/graphic",'esri/map','dojo/_base/lang',
"jimu/loaderplugins/jquery-loader!./js/jquery.min.js, ./js/bootstrap.min.js,./js/select2.min.js,./js/jquery.plugin.min.js"
function(declare,BaseWidget, Query, QueryTask,Polygon,Extent,SimpleFillSymbol,GraphicsLayer,SpatialReference,SimpleLineSymbol,Graphic,Map,lang) {
var clazz = declare([BaseWidget], {
baseClass: 'Test',
startup: function startup() {
$('#cmbRegions').select2();
this.inherited(arguments);
this.onOpen();
this.init();
this.executeTask();
_getMapId: function(){
alert(this.map.id);
onOpen:function onOpen(){
var panel=this.getPanel();
panel.position.width=300;
panel.position.height=300;
panel.setPosition(panel.position);
panel.panelManager.normalizePanel(panel);
executeTask:function executeTask(){
var strURL="https://localhost:6080/arcgis/rest/services/Complex_New_App/MapServer/12";
var query = new Query();
var queryTask = new QueryTask(strURL);
query.where = "1=1";
query.outSpatialReference = {wkid:4326};
query.returnGeometry = false;
query.returnDistinctValues=true;
query.outFields = ["Aname"];
queryTask.execute(query, function(results){
$('#cmbRegions').empty().trigger("change");
$("#cmbRegions").append('<option value=اختر selected>اختر</option>');
for(var k=0;k<results.features.length;k++){
var newOption = new Option(results.features[k].attributes.Aname, k, false, false);
$('#cmbRegions').append(newOption).trigger('change');
init: function init() {
$('#cmbRegions').on('select2:select', function (e) {
var data = e.params.data;
query.where = "Aname="+"'"+data.text+"'";
query.returnGeometry = true;
alert(results.features.length);
var polygon = results.features[0].geometry;
var polygonExtent = polygon.getExtent();
var extent = new esri.geometry.Extent(polygonExtent.xmin, polygonExtent.ymin, polygonExtent.xmax, polygonExtent.ymax, new SpatialReference({ wkid: 4326 }));
var pg = new Polygon(new esri.SpatialReference({ wkid: 4326 }));
if (pg.rings.length > 0) {
for (var i = 0; i < pg.rings.length; i++) {
var ring = pg.rings[i];
pg.addRing(ring);
var ext=pg;
var centerPt = ext.getCentroid();
var graphic = new Graphic(polygon);
var sfs = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_DIAGONALCROSS, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([51, 102, 255, 2]), 4), new dojo.Color([51, 102, 255, 4]));
graphic.setSymbol(sfs);
this.map.graphics.clear();-------------------------------------Error line
this.map.graphics.add(graphic);----------------------------Error Line
return clazz;
please help.......................
 Thanks in advance
KenBuja
MVP Esteemed Contributor
Note: you should move this to the ArcGIS Web AppBuilder Questions place to get more attention. Also use the code formatting tools to make your code easier to read
When using "this", you have to take steps to make sure it's referring to the correct object. When you call a function, you have to use lang.hitch to retain its original context.
$('#cmbRegions').on('select2:select', lang.hitch(this, function (e) {
KenBuja
