Looking for Identify widget for invisible features
1298
06-15-2017 01:34 PM
by Anonymous User
Not applicable
What are the recommended solution(s), if any, among the existing shipped and/or custom widgets for the following scenario?
At small scales, a layer has too many features to display, so a different layer with dissolved features is displayed instead. But the configurator wants an identify-like widget to return a pop-up of information on the original, invisible feature that exists where the user has clicked (and preferably highlight its outline).
Has this situation already been discussed elsewhere?
Tags (1)
RobertScheitlin__GISP
Rod,
   You can use the Identify Widget and setup the identify layer to be your detailed layer and even if the layer is off you can set the identify widget to return results for it anyway.
https://community.esri.com/docs/DOC-3250-identify-widget-version-23-02172017
Rod,
