LocalLayer Widget 2.2 not closing in 2.4
2162
06-10-2017 07:38 AM
TimHayes
I just installed WAB DE 2.4 with the LocalLayer Widget 2.2.
When I use the LL Widget, I add my Dynamic Layer, but the window does not close. Hitting Ok or Cancel does nothing. I must exit the entire app and reopen it, then start over again. Any layers added do not stick.
Is this a bug with WAB DE 2.4 or just in the LL Widget 2.2?
(I have used the LL Widget 1.4 very successfully with the WAB DE 2.0.1)
TimHayes
I found the answer. It was simple. I zipped and exported each of my WebMaps inside WAB DE 2.0.1. Then inside WAB DE 2.4 I imported them. The LL Widget came over just fine. It works.
TimHayes
Halid_Salum
Hi Adrian... Can i have you help please.?
am sorry am having problem right here. I was trying to download Utility Network Editing And Analysis Extension but I can't. every time i tried i meet with this information
This site can’t be reached
The connection was reset.
Try:
  • Checking the connection
  • Checking the proxy and the firewall<data:text/html,chromewebdata#buttons>
ERR_CONNECTION_RESET
Halid_Salum
Owh. Thanks but i can't even download. can you send me that Zipped Utility Network Editing And Analysis file please?
