Label feature with text for printing
1600
02-15-2019 09:17 AM
by Anonymous User
Not applicable
Here is the scenario.
A user uses the add data widget to add a .csv.
The user can seclect a newly added point and show the attributes in a pop up.
How do we create a label (text) that shows the attributes of a selected point so that the map can be printed with the newlt added labels?
RobertScheitlin__GISP
Scott,
  So is your scenario that you want to label all csv points that have been added with all their attributes? If so that could get very messy.
by Anonymous User
Not applicable
It could, so I was hoping that the user could select a point and add the attributes for that point only, or a couple of points at the users discretion.
This would be very valuable for other layers as well.
Scott Foster
GIS Specialist
Pipelines & Terminals
Direct: (210)-345-5198
Cell: (713)-240-7770
Email: [email protected]<mailto:[email protected]>
Scott,
   That is where this is going to get pretty involved. There is no out of the box selection of features in the map ability without custom widget development. So the first part would be to handle the selection of the points. Your custom widget would have to use the drawBox jimu dijit to draw a graphic on the map to allow for a query of the featureLayer that was added to the map with the csv results. Then once the featureLayer.queryFeatures method is done the selected points would need to be looped over and the geometry of the selected features would be added to a new GraphicsLayer in the map and the symbol of those graphics would have to be a TextSymbol with the attribute values. Placement and multiple attributes would be the main issue. This is going to be a fairly involved development effort.
