JSAPI 3.x map centerAndZoom method
1807
10-20-2020 09:01 AM
by Anonymous User
Not applicable
Hello All,
I am trying to write a widget using WAB 2.16 that needs to be able to center and zoom upon startup.  I created an event handler for the map click event as a test, and tried the following code inside:
this.map.centerAndZoom(event.mapPoint0.5);
Nothing happens upon calling the centerAndZoom method and I get the following error in the console:
"Unable to get property 'resolution' of undefined or null reference"
What did I miss?
Thank you.
RobertScheitlin__GISP
Damon,
   Have you verified that this.map is not null in your code scope?
by Anonymous User
Not applicable
Hi Robert,
I was able to console.log the map object.
Strange. Can I see your code?
by Anonymous User
Not applicable
Sure:
define(['dojo/_base/declare'
        'jimu/BaseWidget'
        'dojo/on'
        'dojo/_base/lang'
        'esri/layers/FeatureLayer',
        'esri/layers/layer'
        'jimu/dijit/FeatureSetChooserForSingleLayer',
        'jimu/dijit/FeaturelayerChooserFromMap',
        'jimu/LayerStructure',
        'dojo/Deferred',
        'esri/tasks/query',
        'esri/symbols/SimpleMarkerSymbol',
        'esri/Color',
        'jimu/SelectionManager',
        'esri/geometry/Point',
        'esri/SpatialReference',
        'esri/geometry/webMercatorUtils'],
  function(declare
    BaseWidget
    on
    lang
    FeatureLayer
    layer
    LayerStructure
    Deferred
    Query
    SimpleMarkerSymbol
    Color,
    SelectionManager,
    Point,
    SpatialReference,
    webMercatorUtils) {
    //To create a widget, you need to derive from BaseWidget.
    return declare([BaseWidget], {
      // Custom widget code goes here
      baseClass: 'jimu-widget-mywidget',
      token: null,
      graphic: null,
      _def: null,
      //this property is set by the framework when widget is loaded.
      //name: 'CustomWidget',
      //methods to communication with app container:
      // postCreate: function() {
      //   this.inherited(arguments);
      //   console.log('postCreate');
       startup: function() {
        this.own(this.map.on('click'lang.hitch(thisthis.mapOnClickHandler))); //this.map.on("click", this.mapOnClickHandler);
       mapOnClickHandler: function(event)
         //console.log(this.map);
         //this.map.centerAt(event.mapPoint);
      // onOpen: function(){
      //   console.log('onOpen');
      // onClose: function(){
      //   console.log('onClose');
      // onMinimize: function(){
      //   console.log('onMinimize');
      // onMaximize: function(){
      //   console.log('onMaximize');
      // onSignIn: function(credential){
      //   /* jshint unused:false*/
      //   console.log('onSignIn');
      // onSignOut: function(){
      //   console.log('onSignOut');
      // onPositionChange: function(){
      //   console.log('onPositionChange');
      // resize: function(){
      //   console.log('resize');
      //methods to communication between widgets:
Damon,
  Sorry I missed this before. The second argument on the centerAndZoom method is LevelOrFactor. But 0.5 as your code has is only applicable to a map that is using a ArcGISDynamic Map service as it's basemap.
When using an ArcGISTiledMapServiceLayer, the map is zoomed to the level specified.
When usingDynamicMapServiceLayer, the map is zoomed in or out by the specified factor. For example, use 0.5 to zoom in twice as far and 2.0 to zoom out twice as far.
Change your 0.5 to a LOD of the base map like 16 and the error is gone.
