.js to .json
8210
12
06-01-2015 04:10 PM
RickeyFight
I know this is stupid but I cannot figure out how to get my js to pull some of my config.json into it.
Does it have to be a function?
After viewing sample code, I see that it can be done with a function.
LocalLayer widget:
this.config.layers.layer.forEach(function (layer) {
Is there any documentation/ videos/ examples on how this can be done.
I am looking for a way to amend the config json and have the script reflect that.
Such as
js
var Exp = "fromjson";
json
"fromjson": "crime = 'Larceny/Theft' ",
Thanks!
RickeyFight
Robert,
I am calling   this.config.crimes;  in the startup function.
I have changed the scope of the variable (using Stan suggestions above) trying to make it work.
I am sure you are tired of seeing this code:
                    //setup click event for buttons
                    query("select").forEach(function (node) {
                        on(node, "click", function (e) {
                            var target = e.target || e.srcElement;
                            //----Number of Features---------------
                            lLayer.on("update-end", function (evt) {
                                dom.byId("featcount").innerHTML = " " + evt.target.graphics.length;
                                var crimeDate = this.config.crimes;
                            switch (target.value) {
                              case "106":
                                defExp2 = crimeDate;
                                break;
StanMcShinsky
Another thing that was throwing me off some was I was trying to edit the wrong config file.
I was editing an app in the arcgis-web-appbuilder-1.1.1\server\apps folder (not the stemapp) and tried to make changes to the config file in the widget folder but I forgot that the config file that the widget was reading was in the <root>\configs\<widgetname>config_<widgetname>.json. Maybe this might help?
-Stan
RickeyFight
Stan,
That was it. I tired it yesterday but without the var you suggested. I needed to change the widget configs file and not the config file inside the widget folder.
The scope confuses me though I have to define the variable outside the function I though would need it.
//lots of functions
Thank you Robert Scheitlin, GISP​ and Stan McShinsky
