Imagery With Dojo Horizontal slider
3725
8
12-01-2017 03:19 PM
HushamMohamed1
Hi,   I create  an new widget based on the demo template,  to make Imagery slider widget.
So far its working fine and the widget serve only 2 imagery I will add more to the slider later..  Now  I need to accomplish following task with the slider. I do appreciate any help on that.
1- When opening the widget I Need certain imagery year 2015 to be added.
2- When closing the widget I need to remove all the imagery from the map..
3-  How can to Style the height of the slider.
here is my slider code  in startup function.
   startup: function() {
        this.inherited(arguments);
        //this.mapIdNode.innerHTML = this.map.id;
map=this.map;
          var air2011= new ArcGISImageServiceLayer("http://mydomain.com/arcgis/rest/services/Aerials/Aerial2001/ImageServer" ,{ id: "Aerials 2001", visible: true });
                var air2015= new ArcGISImageServiceLayer("http://mydomain.com/arcgis/rest/services/aerials/Aerials2015/ImageServer", { id: "Aerials 2015", visible: true });
         // Create the rules
                 var rulesNode = domConstruct.create("div", {}, dom.byId("slider"), "first");
                this.sliderRules = new HorizontalRule({
                   // container: "topDecoration",
                    count: 11,
                    style: "width: 5px; "
                }, rulesNode);
                // Create the labels
                var labelsNode = domConstruct.create("div", {}, dom.byId("slider"), "first");
                this.sliderLabels = new HorizontalRuleLabels({
                    //container: "topDecoration",
                    labels:["2013","2015","2016"],
                    labelStyle: "font-size: 15px;"
                }, labelsNode);
                  //create the slider
                  var slider = new HorizontalSlider({
         value: 0,
         minimum: 0,
         maximum: 3,
         discreteValues: 3,
         intermediateChanges: false,
         style: "height:10px; width: auto; color:red;",
          onChange: function(value) {
             //console.log(value);
           // var sliderValue = dom.byId("vertSlider");
    if(value == 0){
         console.log(value);
        map.removeLayer(air2015);
        map.addLayer(air2011);
    }else if(value == 1.5){
         console.log(value);
        map.removeLayer(air2011);
        map.addLayer(air2015);
     },     "slider");
                // Start up the widgets
                slider.startup();
                sliderRules.startup();
                sliderLabels.startup();
        console.log('startup');
       onOpen: function(){
         console.log('onOpen');
       onClose: function(){
        console.log('onClose');
RobertScheitlin__GISP
Husham,
   Try this:
define(['dojo/_base/declare',
    'dojo/on',
    'dojo/_base/lang',
    'dojo/dom-construct',
    'esri/layers/ArcGISImageServiceLayer',
    'dijit/form/HorizontalRule',
    'dijit/form/HorizontalRuleLabels',
    'dijit/form/HorizontalSlider',
    'dijit/_WidgetsInTemplateMixin',
    'jimu/BaseWidget'],
  function(
    declare,
    on,
    lang,
    domConstruct,
    ArcGISImageServiceLayer,
    HorizontalRule,
    HorizontalRuleLabels,
    HorizontalSlider,
    _WidgetsInTemplateMixin,
    BaseWidget) {
    //To create a widget, you need to derive from BaseWidget.
    return declare([BaseWidget, _WidgetsInTemplateMixin], {
      baseClass: 'widget-imageryslider',
      air2011: null,
      air2015: null,
      postCreate: function() {
        this.air2011 = new ArcGISImageServiceLayer("http://mydomain.com/arcgis/rest/services/Aerials/Aerial2001/ImageServer", {
          visible: true
        this.air2015 = new ArcGISImageServiceLayer("http://mydomain.com/arcgis/rest/services/aerials/Aerials2015/ImageServer", {
          visible: true
        // Create the rules
          count: 11,
        }, rulesNode);
          labels: ["2013", "2015", "2016"],
        }, labelsNode);
        //create the slider
          value: 0,
          minimum: 0,
          maximum: 3,
          discreteValues: 3,
          onChange: lang.hitch(this, function(value) {
            if(value == 0) {
              console.log(value);
              this.map.removeLayer(this.air2015);
              this.map.addLayer(this.air2011);
            } else if(value == 1.5) {
              console.log(value);
              this.map.removeLayer(this.air2011);
              this.map.addLayer(this.air2015);
        }, "slider");
        slider.startup();
      onOpen: function() {
        if(!this.map.getLayer("Aerials 2015")){
      onClose: function() {
        if(!this.map.getLayer("Aerials 2001")){
        if(this.map.getLayer("Aerials 2015")){
Husham,
   Try this:
    'dojo/on',
    'dojo/_base/lang',
    'jimu/BaseWidget'],
  function(
    declare,
    on,
    lang,
    domConstruct,
    HorizontalRule,
    HorizontalSlider,
    BaseWidget) {
      air2011: null,
      air2015: null,
          visible: true
          visible: true
        // Create the rules
          count: 11,
        }, rulesNode);
        }, labelsNode);
        //create the slider
          value: 0,
          minimum: 0,
          maximum: 3,
          discreteValues: 3,
            if(value == 0) {
              console.log(value);
              console.log(value);
        }, "slider");
        slider.startup();
HushamMohamed1
Thank you Robert,
I came up with the same solution except onOpen  and onClose,  its more clean than mine...
Thank you so much
HushamMohamed1
Hi Robert,
its all about the variable scope right?
Correct
HushamMohamed1
Thank you Again,  its Working Perfect Now.. after little modification..
If I need to convert this widget to a configurable widget what do I need, if you can direct me to steps or sample.
Thanks
There is not a real good guide or source for that. You just need to look at a simple out of the box esri widget for coding guidance.
HushamMohamed1
Still need to fix the initial slider value to 4 when we open the widget for the second time without refreshing the page.
Thanks
Just move the slider var to a global like air2015 and then do
this.slider.value = 4;
