Identify Widget
1605
03-01-2017 07:07 AM
soniamonga
Robert, I am using the identify Widget version 1.3.0.1 and it was working fine up until recently. We had to add new fields and for some reason the identify widget displays the field name, but without retrieving any values. Would you have any ideas to handle this issue? We are not ready to upgrade the app to the new webapp builder version yet.
rscheitlin
Appreciate your help!
Thanks
Sonia
RobertScheitlin__GISP
Sonia,
   You need to go back into WAB where you created the app and remove the fields for that layer and re-add them so that the widget config has the proper field names.
soniamonga
Robert, I tried that already. I also tried creating a new app, and using the identify widget. Still not populating the values for those fields. Any other ideas?
Sonia,
  Check the browsers web console and see if there are any errors shown there.
