Identify Widget - Sorting result window with date
1503
09-18-2019 08:05 AM
Pierre-LucBoivin
I would like to modify the Identify widget result popup windows from Robert Scheitlin. I don't have experience with javascript but have some in python and html/css, would it be very complicated to get to this example and sort the result with descending date ?
In brief :
  • Remove the layer name
  • Place first and second attribute on the same line
  • Sort the result order with date
Identify_widget_originalIdentify_widget_modify
Thanks a lot for you help
RobertScheitlin__GISP
Pierre-Luc,
   What you are wanting to do is not going to be something that you with no JS coding experience could easily manage.
Pierre-LucBoivin
Thanks Robert ! I guess I will have to dive in the javascript learning
