Identify Selected Feature
2960
01-20-2016 07:45 AM
TomLeMahieu
In the WAB, I use the eSearch widget to select features.  I use the map Identify to identify features.  The problem is that now selected features always get identified twice.  Is there any way to limit the Identify popup for any feature in the Selected layer.
No features selected:
Select a feature:
RobertScheitlin__GISP
Tom,
   This would be the designed out come from using a eSearch layer that points to your parcels and the same layer already have a popup defined for it. I am considering make the popup for eSearch results a configurable option that you can disable popups for eSearch results. But currently what you are seeing is the designed behavior.
TomLeMahieu
Here's one Identify:
Here's the second:
Tom,
TomLeMahieu
Thanks Robert!  I just wanted to make sure it wasn't currently an easy configuration item.  It may be a nice option in the future.
