How to use Query() to pull intersecting features through a widget
4813
10
02-17-2017 11:57 AM
StahlyEngineering
How does one correctly use a query and QueryTask to retrieve features in a predefined layer that intersect a selected feature?
var queryTask = new QueryTask("http://services6.arcgis.com/3aTanasiPG0rbYg4/arcgis/rest/services/PlatBook_Test/FeatureServer/1");
var query = new Query();
query.returnGeometry = true;
query.outFields = ["SECDIVID"];
query.spatialRelationship = Query.SPATIAL_REL_INTERSECTS;
// execute query
queryTask.execute(query);
current piece of code spits out an error of faulty query arguments.
Once the query works the next task will be to output a specific field from the output into an array.
Any help is appreciated, I'm very new to writing scripts and have no idea what I'm doing.
Cheers!
RobertScheitlin__GISP
Stahly,
   Well I see a major issue. You are trying to set the queries geometry to a string (line 34)...
define([
    'dojo/_base/declare',
    'jimu/BaseFeatureAction',
    'jimu/WidgetManager',
    'esri/tasks/QueryTask',
    'esri/tasks/query',
    "esri/SpatialReference"
], function(declare, BaseFeatureAction, WidgetManager, QueryTask, Query, SpatialReference) {
    var clazz = declare(BaseFeatureAction, {
        //Icon format:50x50px main icon. _default/_hover 16x16px popup icons
        iconFormat: 'png',
        isFeatureSupported: function(featureSet) {
            //test feature compatibility for the action
            return featureSet.displayFieldName == 'OwnerName';
        onExecute: function(featureSet) {
            WidgetManager.getInstance().triggerWidgetOpen(this.widgetId)
                .then(function(myWidget) {
                    //pointless text output here
                    var fName = [];
                    fName[0] = featureSet.spatialReference.wkt;
                    fName[1] = featureSet.displayFieldName;
                    console.log('log: step 0 ' + fName[0]);
                    // spatial query: select all PLSS_2ndDivision INTERSECTING the input feature
                    console.log('log: step 0.1 ');
                    var Q = new Query();
                    Q.returnGeometry = true;
                    Q.outSpatialReference = new SpatialReference({
                        wkid: 102100
                    Q.outFields = ["SECDIVID"];
                    Q.geometry = 'polygon';
                    Q.spatialRelationship = Query.SPATIAL_REL_INTERSECTS;
                    console.log('log: step 0.2 ' + Q.geometry);
                    console.log('log: step 0.2 ' + Q.outSpatialReference.isWebMercator());
                    console.log('log: step 0.2 ' + Q.spatialRelationship);
                    console.log('log: step 0.2 ' + queryTask.url);
                    queryTask.execute(Q);
                    myWidget.SelectParcels(fName);
    return clazz;
I think you need to be setting it to a selected feature geometry right? Something like:
Q.geometry = featureSet.features[0].geometry;
Beyond that I have no idea what this line is doing:
Or Where is your QueryTask result handler function?
Stahly,
  You need to set the
query.geometry = x // where x is the geometry of the selected feature.
StahlyEngineering
Did that, now I get the following: TypeError: Cannot read property 'wkid' of undefined
//Q.outSpatialReference = (102100);
//Q.outFields = ["SECDIVID"];
console.log('log: step 0.2 '+typeof(queryTask));
Thanks a bunch!
Stahly,
  The querys outspatialreference is expecting a SpatialReference object not just a number in parentheses. So make sure you have the SpatialReference require in your require list and use code like this
Q.outSpatialReference = new SpatialReference(wkid:102100);
Don't forget to mark this question as answered.
StahlyEngineering
Still no go. console logs return return the correct parameters for the query object (geometry, spatial reference wkid number, spatialrelationship). I seem to be getting this type of error when an object isn't actually created, but I'm not sure which object that is.
Stahly,
   I can't say I understand what your saying. Did you add the require for SpatialReference to your require list? Maybe you should post more of your code.
StahlyEngineering
Q.outSpatialReference = new spatialReference(102100);
console.log('log: step 0.2 '+Q.geometry);
console.log('log: step 0.2 '+Q.outSpatialReference.isWebMercator());
console.log('log: step 0.2 '+Q.spatialRelationship);
console.log('log: step 0.2 '+queryTask.url);
log: step 0.2 polygon
ShowVertexFeatureAction.js?wab_dv=2.3:37 log: step 0.2 true
ShowVertexFeatureAction.js?wab_dv=2.3:38 log: step 0.2 esriSpatialRelIntersects
ShowVertexFeatureAction.js?wab_dv=2.3:39 log: step 0.2 http://services6.arcgis.com/3aTanasiPG0rbYg4/arcgis/rest/services/PlatBook_Test/FeatureServer/1
init.js:113 TypeError: Cannot read property 'wkid' of undefined
SpatialReference object need to have a capital S in your code. JS is a case sensitive language.
StahlyEngineering
Did that, still getting the same error. Here's my entire code. Maybe I'm missing references?
define([
'esri/tasks/query',
], function(declare, BaseFeatureAction, WidgetManager, QueryTask, Query, SpatialReference){
iconFormat: 'png',
isFeatureSupported: function(featureSet){
onExecute: function(featureSet){
var fName = [];
console.log('log: step 0 '+fName[0]);
Q.outSpatialReference = new SpatialReference({wkid:102100});
return clazz;
Stahly,
define([
    'esri/tasks/query',
        iconFormat: 'png',
                    var fName = [];
                        wkid: 102100
    return clazz;
