How to updated Config.JSON file everytime we make change in webmap
1062
05-27-2020 10:16 AM
Shalineemishra
I created a web application which added some layers to the webmap. I downloaded my application and deploy it on the IIS server that is running perfectly.But due to the requirement of the project, I had to add some new layers to the web map and these layers successfully loaded in webmap and it is also visible on the map of web app builder application.But these layers are not visible in widgets i.e.- Edit, query widget....etc.
    I want to updated config.JSON file whenever I make any changes to the webmap, So please suggest an easy way to update the config.JSON file of web application.
