How to make widget as expandable in WAB 2.6
2728
7
09-10-2018 07:26 AM
SivaramKrishnan2
I want to make my widget as expandable.
can anyone help me in fixing this.
RobertScheitlin__GISP
What theme are you using?
SivaramKrishnan2
Robert,
I'm using Foldable Theme.
Sivaram,
   In the foldable theme if you have a widget added to the header controller widget then they will use the foldable panel. Widgets placed in the on screen widget placeholders will use the on screen widget panel (that does not have the fold button).
SivaramKrishnan2
Hi Robert,
I want to expand my widget as shown in the below image.
Is that possible to do from the Foldable Theme in WAB 2.6
Regards
Siva
Is that widget in the Header controller or in an on screen widget placeholder?
SivaramKrishnan2
Robert, the widget is in the header controller
Siva,
Header Controller widget are not sizable by design. The only way to change that is to use a different panel for the HeaderController widget. In the main config.json for the app search for "themes/JewelryBoxTheme/panels/FoldablePanel/Panel" and replace with "jimu/OnScreenWidgetPanel"
and refresh your app.
