How to keep different point symbol for identify and draw widget
3718
8
08-18-2016 10:37 PM
deepthip
I want to keep different point symbols for draw and identify how to change them. Attaching the screen shot for better understanding
In the above screen shots both the draw and identify have the same symbol for point.
Do changes i need to do for it please suggest.
RobertScheitlin__GISP
Deepthi,
   Sure just add this css rule to the Identify widgets css/style.css
.jimu-widget-identify .jimu-draw-box .point-icon{
    background-image: url(images/draw_point.png);
Deepthi,
   Are you talking about the button icon or the actual symbol that is placed on the map?
deepthip
I want to know how to change the button icon which is visible in the above snapshots.
Deepthi,
   That is a css change and is dependent on which theme you are talking about.
deepthip
I using tab theme. what changes need to be done in css
deepthip
Hi Robert,
I need to change the point icon only for identify widget, whereas point icon for Draw widget should remains same. Here in DrawBox.html template, for point "draw-item point-icon" class has been used. If i change the image for the point, Then it is going to change for both the widgets.
Can you suggest, How to override the point icon based on the widget.
Deepthi
Deepthi,
deepthip
Thanks Robert for your suggestions, its working fine
Deepthi,
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
