How to download WAB app code
2137
12-16-2014 10:12 AM
BarnabyRockwell
How does one download code of a WAB app to customize it and eventually host on my server? I see a way to download the non-WAB app "templates", but I can't find a way to download WAB app code.
Does one create and edit a WAB app online, and then download it for further customization using WAB Developer Edition which will soon be available (I assume)?  I just started looking at WAB last week, and am rather clueless.
I saw this:
http://www.arcgis.com/home/item.html?id=fffd70b754594c54bc58d90d4e897e19
but I'm wondering if one can download code for an app created online that already has your service layers and widgets in there.
Thank you in advance...
RobertScheitlin__GISP
Barnaby,
   Any work that you do online with the AGOL WAB version is going to be of limited use, as far as further CODE customization as all of the widgets and core WAB code will be minified. You can of course just grab all of the json files and paste those into your WAB Developer version App (after you create a new app). I would really hold tight until the WAB Developer version is available.
RebeccaStrauch__GISP
See Julie Powell's response at end of
Download Released WAB?  talking about how/when the Web Application Builder developers version will be available.  That will be the version I believe you will want to use.
Barnaby,
BarnabyRockwell
Thank you both very much.  I'll take Robert's advice (I always do ), and hold on until WAB DEV release.
Cheers,
Barnaby
