How to display Hebrew text in pdf from my custom widget, using jsPDF library
21932
12
12-23-2020 12:32 AM
Labels (2)
MichaelLev
I'm developing custom widgets for WAB (Develper Edtion) 2.17, Launchpad Theme, on 3D Scenes (ArcGIS API for javascript 4.17), on our compamy portal (version 10.7.1).
I am still a newbie...
I need, from within javascript code of a custom widget, to create pdf file which will contain Hebrew text. I found jsPDF library, incorporated it by its jspdf.umd.min.js file and it creates pdf all right, but I have not succeeded to show Hebrew fonts.
jsPDF is good by the capability to show tables, so I wish to use it right. Maybe I have not set up all things as should be?
Does anyone have some sample code that can output Hebrew text (or Arabic, for example) to pdf, using jsPDF library?
Sample using other library like pdfmake will also help.
Help will be greatly appreciated,
Michael
KaramShabita
I did the same as you explained but didn't convert the ttf in the fontconverter . converting the ttf file gives a .js file back how should it be used ?
also I noticed the font was set correctly in the jsPDF
AlaaYahia
I have these files:
1- David-normal.js
import { jsPDF } from "jspdf";
var font = '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';
var callAddFont = function () {
console.log("here");
this.addFileToVFS('David-normal.ttf', font);
this.addFont('David-normal.ttf', 'David', 'normal');
jsPDF.API.events.push(['addFonts', callAddFont])
2- David-normal.ttf
3- reportGenerator.js
import jsPDF from "jspdf";
import "jspdf-autotable";
import "David-normal.js";
// Date Fns is used to format the dates we receive
// from our API call
import { format } from "date-fns";
// define a generatePDF function that accepts a reports argument
const generatePDF = reports => {
//initialize jsPDF
const doc = new jsPDF();
doc.addFont("David-normal.ttf", "David", "normal");
doc.setFont("David"); // set font
doc.setFontSize(12);
function fix(str){
return str.split('').reverse().join('');
// define the columns we want and their titles
//const tableColumn = [ fix("שם עובד"),fix("מספר פרויקט"),fix("תאריך דיוח"),fix("כניסה"),fix("יציאה"),fix("תיאור") ];
const tableColumn = [fix("תיאור"),fix("יציאה"),fix("כניסה"),fix("תאריך דיווח"),fix("מספר פרויקט"),fix("שם עובד")]
// define an empty array of rows
const tableRows = [];
// for each report pass all its data into an array
reports.forEach(report => {
const reportData = [
report.description.split('').reverse().join(''),
report.end_time,
report.start_time,
report.reporting_date,
report.project_id,
report.worker_name.split('').reverse().join(''),
// called date-fns to format the date on the report
format(new Date(report.reporting_date), "yyyy-MM-dd")
// push each reports's info into a row
tableRows.push(reportData);
// startY is basically margin-top
doc.autoTable(tableColumn, tableRows, {styles: {font: "David", align: 'right', isSymmetricSwapping: true, isInputVisual: true, isOutputVisual: false}});
const date = Date().split(" ");
// we use a date string to generate our filename.
const dateStr = date[0] + date[1] + date[2] + date[3] + date[4];
// ticket title. and margin-top + margin-left
let text = "דוח שעות:".split('').reverse().join('');
doc.text(text, 100, 10, {styles: {font: "David" }});//, {align: 'right', isSymmetricSwapping: true, isInputVisual: true, isOutputVisual: false}
// we define the name of our PDF file.
doc.save(`report_${dateStr}.pdf`);
export default generatePDF;
 Then I called the generatePDF with the data.
import generatePDF from "reportGenerator";
generatePDF(reports)
KaramShabita
Thank you very much!
