How do I use map tips within web app builder?
10909
13
05-20-2015 10:50 AM
BrandonKeinath1
Does anyone know how I use map tips within web app builder?  I see the option within the properties of the layer and we've been using them a lot in our ArcReader maps.  The pop-ups works well but for some quick information I'd like to explore using the map tips.  I see Robert Scheitlin​ has a flex app that uses them but I'm not sure how to get started.  Any information would be great.
And here is the link to the flex example http://www.arcgis.com/home/item.html?id=ce63f1bdd5e64068b9a4fadd2028e379
Brandon
BrandonKeinath1
Thanks Larry,
Am I understanding you correctly that all of the code you posted above goes into the config file for the headless widget?
Brandon
LarryStout
Brandon,
The first part (7 lines) is all that goes into the config file.  The rest goes into the widget.  If you like, I could put the map tips together in the Anvil Widget I posted and you could download it.  I can help as little or as much as you need.
Larry
BrandonKeinath1
Hi Larry,
I think it would be helpful to see it inside of the anvil widget.  That way I can compare your original code to how you put it into the files.  Thanks for the help!
Brandon
LarryStout
Brandon,
I added a bit of code to make it stand alone.  You will find it here.
Larry
