How do I use map tips within web app builder?
10878
13
05-20-2015 10:50 AM
BrandonKeinath1
Does anyone know how I use map tips within web app builder?  I see the option within the properties of the layer and we've been using them a lot in our ArcReader maps.  The pop-ups works well but for some quick information I'd like to explore using the map tips.  I see Robert Scheitlin​ has a flex app that uses them but I'm not sure how to get started.  Any information would be great.
And here is the link to the flex example http://www.arcgis.com/home/item.html?id=ce63f1bdd5e64068b9a4fadd2028e379
Brandon
StanMcShinsky
Brandon Keinath​,
I know Larry Stout​​ has done map tips in this application
ArcGIS Web Application
Maybe he can shed some light on this with out us having to reinvent it.
-Stan
BrandonKeinath1
Hi Stan,
That would be great.  I like not reinventing things...or more correctly asking others to reinvent things for me.
Brandon
LarryStout
Brandon,
The trickiest part of map tips is where to put the code.  I have a "headless" widget that does the map tips and lots of other things.  It does so many things that I'm having trouble finding the time to document it so I can post it.  In it's config file, I have something like this:
"featureLayerMapTips": {
  "layers": {
    "Address Points (E911)": {
      "mapTip": "Address Point (E911): <b>{FULL_ADDR}</b><br><i>Click for more info</i>"
If map tips are configured, we need to create a popup:
// Create the MapTip dialog
this.mapTip = new TooltipDialog({
  style: "position:absolute; max-width:300px; z-index:100;",
  "class": 'mapTipDialog'
this.mapTip.startup();
Then, I have this code (looping through all of the feature layers to see if map tips are configured):
var mapTipTemplate = lang.getObject(layerLabel + '.mapTip', false, this.config.featureLayerMapTips);
if (mapTipTemplate) {
  on(layer, 'mouse-out', lang.hitch(this, function() {
    if (this.savedSettings.showMapTips) {
      clearTimeout(this.mapTipDelay);
      clearTimeout(this.mapTipLife);
      this._hideMapTip();
  on(layer, 'mouse-over', lang.hitch(this, function(evt) {
      this.mapTipDelay = setTimeout(
        lang.hitch(this, '_showMaptip', mapTipTemplate, evt),
        this.mapTipTimes.delay
Finally, the functions to show and hide the map tips:
_showMaptip: function(mapTipTemplate, evt) {
  // If the user is drawing, don't show the mapTip
  if (this.drawToolActive) {
    return;
  // If there is an info window showing don't show a MapTip.
  if (this.map.infoWindow.isShowing) {
    return;
  var content = lang.replace(mapTipTemplate, evt.graphic.attributes);
  if (this.nullValue && this.nullValueReplacement) {
    content = content.replace(this.nullValue, this.nullValueReplacement);
  this.mapTip.setContent(content);
  popup.open({
    popup: this.mapTip,
    x: evt.pageX + 10,
    y: evt.pageY + 10
  // Fade in the MapTip
  baseFx.animateProperty({
    node: this.mapTip.domNode,
    duration: this.mapTipTimes.fadeIn,
    properties: {
      opacity: 0.85
    onEnd: lang.hitch(this, function() {
      this.mapTipLife = setTimeout(lang.hitch(this, '_hideMapTip'), this.mapTipTimes.life);
  }).play();
_hideMapTip: function() {
  // Fade out the MapTip
    duration: this.mapTipTimes.fadeOut,
    properties: {
      opacity: 0
      popup.close(this.mapTip);
  }).play();
Keep in mind that map tips can be very annoying.  I give my users a way to turn them off completely, and I have a system where other widgets can publish a topic to turn them on and off (e.g. the Draw Widget).  The hide automatically a few seconds after the cursor leaves the map tip.  The don't show at all if an infoWindow is open.
Larry
StanMcShinsky
Way to go Larry! That looks like it took a lot of work.
-Stan
LarryStout
The devil is in the details.
BrandonKeinath1
Thanks Larry!
I don't have a "headless" widget, or sometimes a head it feels like, so where would you suggest I put the code?  Or is it easy to create my own "headless" widget that could house just the code you wrote?
Brandon
LarryStout
Now that you ask, I think I'll write a very simple example and post it.  I'll let you know, but it shouldn't take but a few hours, and I think it might be useful for lots of folks.
Larry
BrandonKeinath1
That would be great Larry!  I look forward to taking a look when you have time to post it.
Brandon
LarryStout
Here it is, Brandon.
Larry
