How could be 2 different looks for same esri 3D Layer List widget?
2478
09-03-2020 09:48 AM
MichaelLev
For API 4.16, 3D Layer List widget has 2 different looks:
  1. In Sample Code - LayerList widget
  2. In Web AppBuilder (Developer Edition)
Both use same widget - "esri/widgets/LayerList", so how I see 2 totally different looks?
Attached is screenshots showing the 2 different lloks.
Michael
RobertScheitlin__GISP
Michael,
   The WAB team takes the JS API and further customizes and extends it. So the fact that they appear different is not surprising.
Michael,
MichaelLev
Where is the customization code? I have not seen it inside LayerList widget. What am I not seeing?
Have you looked at the css rules?
MichaelLev
I’ll look tomorrow morning. I also remember there is “item.js” file. I’ll look also in it to understand how the change stems from the code.
