How can I remove pop-ups after adding map services using Add Layer widget?
2426
06-20-2016 05:59 PM
BenjaminKim1
I was able to add map services on the fly using Add Layer widget, but after layers get loaded clicking on a map triggers pop-ups. I don't want these annoying pop-ups to show up after new layers loaded. I know I can set disabling pop-ups in a WebMap, but how can I disable pop-ups after new layers loaded?
If anyone can help me in this issue I would greatly appreciate.
RobertScheitlin__GISP
Benjamin,
Are you talking about this widget AddLayer Widget ? You want popups to be disabled for added layers by default? If you click on the edit (pencil icon) on that layer in the widgets settings page, you can click the red x on the popup to remove the popup for that layer.
