Hover instead of click popup in WAB
3089
8
01-18-2019 08:57 AM
joerodmey
Looking to allow the user to hover their mouse over a point to see the popup, instead of clicking on it. Is this possible in WAB?
Thanks in advance!
RobertScheitlin__GISP
It is possible to do this for a specific layer through custom code but it is not possible to just switch all the maps popups to use hover instead of click or even a wise direction to consider.
joerodmey
Yes that is what I want to achieve. Do you have a sample of how to incorporate this into my existing app?
Thanks
Sorry I do not as I still think this is a poor development decision.
joerodmey
I just want to do it for one layer as requested by my users
CottenhamOpen
I'm curious (Not challenging) why is it a poor dev solution? Client sees it on Google and wants it here? Andrew aka :monkey: Curious George
I am not sure how Goggle handles this behind the scenes, but with esri this would cause a very chatty application (meaning requests to the server every time the mouse coordinates are changed).
RyanKelso
It's a feature that some people want and there's nothing wrong with that.  The problem is poor (lack of) support/implementation in the API because it's one of those things all-knowing esri doesn't think you need.  The solution is a bit hackish because of this, but custom implementation is possible on a layer-by-layer basis if you are ok with using feature layers, which is a problem because IMHO they are not a fully mature feature.
CottenhamOpen
Hi Ryan, it's firmly on the Json to do list. Thanks. I'm meeting Andrew
later this morning and he most likely, or I will get back to you
Best, Terry
