Hidding classification field
5316
17
10-28-2016 07:52 AM
deleted-user-0W0-oLHxDjCX
Hi everyone.
I was using LayerListWidget of WAB and would like to know if it is possible to hide classification field on legend representation.
Best regards
Tags (1)
deleted-user-CQZbjNeBXm49
Ezequias,
Sorry for the late reply (time zone difference), yes I have tried it for quantities and yes it does work but you had need a different approach for that.
1.   Go to your ArcMap TOC (Table of Content) > Then soft click on the "field_name_0" like in the image below > Then press delete > Then mouse click on any area of the TOC
These should solve your issue
Baba
Thank you for the reply. We did the same thing and it does not work. Maybe becouse of the portal or something else. Thanks for your information.
Sincerely
Ezequias
Ezequias,
Where are you making the changes?
Baba
babateepsee‌ on ArcMap as you suggested and than adding it to a Map on Portal.
Ezequias,
How are you adding it to a map in Portal?, do you publish it as a mapservice or add it as a zipped file (.shp)?
Baba
We added it as a Mapservice (from ArcMap) and than added to our map in portal.
Ezequias,
In order for this to work, you need to add the layer (url) as part of your content as a "Dynamic Layer" like this http://webadaptor.domain.com/arcgis/rest/services/foldername/servicename/MapServer (Then give it a proper name) and not like this http://webadaptor.domain.com/arcgis/rest/services/foldername/servicename/MapServer/0 before adding it to a map in portal. See images below:
That is the way it works
Baba
erocha-img-com-br-esridist,
If your question has been answered kindly make the reply that solved your query as the "Answer", so that other people with similar issues can find it easily.
Cheers
Baba
