Hidden zoom controls in WAB
3872
17
02-27-2019 08:45 AM
joerodmey
Built a custom app in web app builder dev edition and now I'm having my zoom controls hidden behind the banner (See image below).
What's going on with this?
joerodmey
RobertScheitlin__GISP
Joe,
  That does Not look like the Launchpad theme at all.
joerodmey
My mistake. Its the foldable theme
OK. This is going to be searching for a needle in a haystack. If you are seeing this issue when creating a new app using the foldable theme then that means you have made your changes in the client\stemapp\themes\FoldableTheme\widgets\HeaderController files.
If it just a certain app that you are duplicating then you need to look for your changes in that apps FoldableTheme\widgets\HeaderController files.
joerodmey
Im going to start at the app level to rule out the duplicate app theory. Where do I look in these files and for what?
Joe, so I take it you can not remember what you changed. Do you remember asking a question about doing this, so that you can go back to that post to look for the code changes you made?
joerodmey
No I cannot remember. I don't believe that I have a post that can help me out
Joe,
   My only advice then is to copy and replace the HeaderController widget from a GOOD app to the app that is having issues.
