Hidden zoom controls in WAB
3879
17
02-27-2019 08:45 AM
joerodmey
Built a custom app in web app builder dev edition and now I'm having my zoom controls hidden behind the banner (See image below).
What's going on with this?
RobertScheitlin__GISP
Have you been playing around with the header size or adjust css rules?
joerodmey
Don't believe so. It only happens in certain apps. What's weird is that I've duplicated an app in WAB and some of the duplicates ones have the issue while others don't.
Joe,
   I have never seen issues like that without someone fiddling with code or css rules.
joerodmey
Where do I look to fix this?
I wouldn't know. So you are sure you made no changes like that to the main stemapp?
joerodmey
If I did it was awhile ago. What file/folder should I look in?
Depends on which theme it is that you are using when you see that issue.
joerodmey
Launchpad
Can you provide a larger screenshot?
