Help with Widget
7195
24
09-16-2015 06:23 AM
TerryGustafson
Robert,
Can you take a quick look at this. I think I’m close. Here is what the widget is supposed to do. User enters Corridor route and offset and it simply returns a point. When I debug it, it returns “function expected TypeError: Function expected.
RobertScheitlin__GISP
Terry,
   What does that link have to do with the constructor options for the SimpleMarkerSymbol?.. Try the link I posted above.
TerryGustafson
Robert,
Thanks for the directions.. Ok, how do I mark this answer and post the code in there?
Terry,
   Is your linter not showing an issue on line 108, 109 and 114? Try adding a comma at the end of 108.
TerryGustafson
I don’t know why but I can’t always see my linter results
Terry,
  Click the spot indicated in this image:
TerryGustafson
Ok, before I had the errors listed in a panel at the bottom..
Terry,
   If you click where my image says click here then the panel will reappear.
Terry,
Clear as mud again.
TerryGustafson
I get the linter remark as to where to click.... when the question is answered there is usually a green icon that says mark question answered.. I don’t see that..
Terry,
   You will not see the option to mark as answered inside your inbox you have to open the thread and then you will see it.
