Help Me With Edit Widget WAB 2.4 DateTime Picker
1442
03-31-2017 01:47 PM
Juan_ManuelAngel
Hi guys i am trying to edit Date in WAB 2.4 but i need the date picker appear with date and time but when i edit the date picker just show me the date like the image prueba_widget, but i need the date time like the ArcGIS Online Table Editor with date and time at the same edition. If you can give me some ideas how to edit WAB 2.4 for developers to do that i  will be awsome, thank you.
RobertScheitlin__GISP
Juan,
  In your web map did you configure the popup and for that field did you check the show time?
If so then you should see a time field also.
Juan,
Juan_ManuelAngel
Thank You Robert that was the solution ! Its help me a lot.
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
