Has anyone made a custom widget to display related data from a feature selection?
7486
12
05-17-2019 10:18 AM
BrianVan_Nostrand
Hi all,
I'm trying to figure out how to put together a web appbuilder widget that will display a formatted table of related attributes from a selected feature. My customer doesn't like how the out of the box attribute table looks.
Has anyone ever tried something like this?
LeoLiu1
Hi Brian,
Try this customized widget, I just quickly copied the codes from the sample I mentioned before.
You probably need to polish the codes to make it more robust.
https://github.com/LeoLiu-EsriAu/WebAppBuilderDEV
Cheers,
Leo.
RowenaTansley1
I have a custom widget that shows a custom report base on a polygon and 3 related tables. Unfortunately it's not yet public, so I can't show it to you.
Basically there is a map click, it does the polygon selection, then finds all the related records and parses JSON. Then it formats the report in the panel. I can try to be more details, or do you have any specific questions?
LeoLiu1
Here is an example:
https://developers.arcgis.com/javascript/3/samples/featuretable_relatedrecords/
It's very easy to migrate into your widget.
BrianVan_Nostrand
This looks like it would do what we need perfectly. Is there a GitHub page or something I can pull the code from and work with it?
Thanks for your help!
DianaWalker1
I am with Brian, is there a publicly available code somewhere?
BrianVan_Nostrand
Here's the code he used:
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<title>FeatureTable - related records</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.28/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.28/esri/css/esri.css">
<script src="https://js.arcgis.com/3.28/"></script>
<style>
html, body, #map{
width:100%;
height:100%;
margin:0;
padding:0;
</style>
<script>
require([
"esri/layers/FeatureLayer",
"esri/dijit/FeatureTable",
"esri/tasks/query",
"esri/geometry/Extent",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/Color",
"esri/map",
"esri/dijit/Popup",
"esri/dijit/PopupTemplate",
"dojo/dom-construct",
"dojo/dom",
"dojo/number",
"dojo/parser",
"dojo/ready",
"dojo/on",
"dojo/_base/lang",
"dijit/registry",
"dijit/form/Button",
"dijit/layout/ContentPane",
"dijit/layout/BorderContainer",
"dijit/form/TextBox"
], function (
FeatureLayer, FeatureTable, Query, Extent, SimpleFillSymbol, SimpleLineSymbol, Color, Map,
Popup, PopupTemplate, domConstruct, dom, dojoNum, parser, ready, on,lang,
registry, Button, ContentPane, BorderContainer, TextBox
parser.parse();
ready(function(){
var popupOptions = {
marginLeft: "20",
marginTop: "20"
// create a popup to replace the map's info window
var popup = new Popup(popupOptions, domConstruct.create("div"));
var map = new Map("map",{
basemap: "topo",
infoWindow: popup,
extent: new Extent({
xmax: -13178092.546668783, xmin: -13180901.607458338,
ymax: 4038066.907666304, ymin: 4036294.524072895,
"spatialReference":{"wkid":102100,"latestWkid":3857}
map.on("load", loadTable);
function loadTable(){
// create a popup template for Bevery Hills
// Trees by block layer
var popupTemplate = new PopupTemplate({
"title": "Beverly Hills Trees By Block",
"fieldInfos": [{
"fieldName": "Point_Count",
"label": "Count of Points",
"format": {
"places": 0,
"digitSeparator": true
"fieldName": "relationships/0/Point_Count_COMMON",
"label": "Sum of species tree count",
"format": {
"places": 0,
"statisticType": "sum"
"fieldName": "relationships/0/COMMON",
"label": "Common Name"
"fieldName": "BLOCKCE10",
"label": "Block"
"description": "There are {Point_Count} trees within census block {BLOCKCE10}",
"showAttachments": false,
"mediaInfos": [{
"title": "Count By Type",
"type": "columnchart",
"caption": "",
"value": {
"theme": "GreySkies",
"fields": ["relationships/0/Point_Count_COMMON"],
"normalizeField": null,
"tooltipField": "relationships/0/COMMON"
var myFeatureLayer = new FeatureLayer("https://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/Beverly%20Hills%20Trees%20By%20Block/FeatureServer/0",{
mode: FeatureLayer.MODE_ONDEMAND,
infoTemplate: popupTemplate,
outFields: ["*"],
//set the definition expression
definitionExpression: "TRACTCE10 = '700902'",
visible: true,
// apply the selection symbol for the layer
var selectionSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color([255, 0, 0, 0.35]), 1),
new Color([255, 0, 0, 0.35]));
myFeatureLayer.setSelectionSymbol(selectionSymbol);
// listen to featurelayer click event to handle selection
// from layer to the table.
// when user clicks on a feature on the map, the corresponding
// record will be selected in the table.
myFeatureLayer.on("click", function(evt) {
var idProperty = myFeatureLayer.objectIdField;
var feature, featureId, query;
if (evt.graphic && evt.graphic.attributes && evt.graphic.attributes[idProperty]) {
feature = evt.graphic,
featureId = feature.attributes[idProperty];
query = new Query();
query.returnGeometry = false;
query.objectIds = [featureId];
query.where = "1=1";
myFeatureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW);
map.addLayer(myFeatureLayer);
// create new FeatureTable and set its properties
var myFeatureTable = new FeatureTable({
featureLayer : myFeatureLayer,
map : map,
syncSelection: true,
showRelatedRecords: true,
showAttachments: true,
fieldInfos: [
alias: 'Area SQ/KM',
editable: false,
format: {
template: "${value}",
places: 3 // number of decimal places
// digitSeparator: true // default is true
// outfields
outFields: ["TRACTCE10", "BLOCKCE10", "GEOID", "NAME", "MTFCC", "ALAND", "AnalysisArea", "Point_Count", "Join_ID"],
}, 'myTableNode');
myFeatureTable.startup();
// listen to row-click event
// to hide visible popups
myFeatureTable.on("row-select", function(evt){
if (map.infoWindow.isShowing){
map.infoWindow.hide();
// listen to show-attachments event
myFeatureTable.on("show-attachments", function(evt){
console.log("show-attachments event - ", evt);
// listen to show-related-records event
myFeatureTable.on("show-related-records", function(evt){
console.log("show-related-records event - ", evt);
</script>
</head>
<body class="claro esri">
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center', splitter:true" style="height:60%">
<div id="map"></div>
</div>
<div id="bot" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom', splitter:true" style="height:40%">
<div id="myTableNode"></div>
</div>
</div>
</body>
</html>
It appears to be JS API code from the 3.28 API. It probably is very easy to migrate into my widget. I don't know how to do that, though.
BrianVan_Nostrand
This appears to be an app built using the ESRI API 3.28. I need this functionality, but within a Web AppBuilder widget. I understand how to build this out in the JS API, but the WAB widget creation is giving me plenty of issues.
LeoLiu1
The codes are very similar to it supposed to be in the widget. You just need to:
1. configure feature actions for your custom widget.
2. in the function that binding to your feature action, determine feature/featureset has related data or not.
3. show the widget UI if it has related data.
I will see if I can figure out some time to build a simple widget sample for you.
BrianVan_Nostrand
Thanks Leo, that would be a huge help.
LeoLiu1
Hi Brian,
Cheers,
Leo.
