GP service
12554
32
08-19-2015 08:37 AM
TerryGustafson
I'm trying to use a gp service to return a point and values from a gp service and can't seem to get the define point to return.  Can anyone help?
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Geometry Service: Relation</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
<style>
html, body, #mapDiv {
height: 100%;
margin: 0;
padding: 0;
width: 100%;
#info {
        bottom: 20px;
color: #444;
height: auto;
font-family: arial;
left: 20px;
margin: 5px;
padding: 10px;
position: absolute;
text-align: left;
width: 200px;
z-index: 40;
.label {
display: inline-block;
width: 4em;
</style>
<script src="http://js.arcgis.com/3.14compact/"></script>
<script>
var map, gp;
require([ "dojo/dom",
"dojo/_base/array",
"dojo/promise/all",
"dojo/json",
"esri/map",
"esri/domUtils",
"esri/graphic",
"esri/graphicsUtils",
"esri/geometry/Point",
"esri/SpatialReference",
"esri/tasks/GeometryService",
"esri/tasks/Geoprocessor",
"esri/tasks/FeatureSet",
"esri/tasks/RelationParameters",
"esri/Color", "esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/config",
"esri/request", "dojo/domReady!"
function(
dom, array, all, JSON,
Map, domUtils, Graphic, graphicsUtils,
Point, SpatialReference, GeometryService, Geoprocessor,
FeatureSet, RelationParameters,
Color, SimpleLineSymbol,
SimpleMarkerSymbol, SimpleFillSymbol,
config, Request) {
var geometryService, geometries, baseGraphics;
map = new esri.Map("mapDiv", {
basemap: "topo",
center: [-111.185, 46.052],
zoom: 15
map.on("click", executeGP);
gp = new Geoprocessor("http://app.mdt.mt.gov/arcgis/rest/services/LRS/LocateFeaturesOnDCandRM/GPServer/Locate%20features%20...");
gp.setOutputSpatialReference({
wkid: 102100
function executeGP(run){
map.graphics.clear();
var pointSymbol = new SimpleMarkerSymbol();
pointSymbol.setSize(14);
pointSymbol.setOutline(new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 1));
pointSymbol.setColor(new Color([0, 255, 0, 0.25]));
var graphic = new Graphic(run.mapPoint, pointSymbol);
map.graphics.add(graphic);
var features = [];
var featureSet = new FeatureSet();
featureSet.features = features;
var params = {
"f": json,
"outSR" : 102100,
"City_Centers" : featureSet,
"geometryType" : esriGeometryPoint,
"features" : [{
"geometry" : {
"x": -12180856.426452411,
"y":  5952832.259593694,
"spatialReference": {
"wkid": 102100
"sr": {
"wkid": 102100
"Search_Radius": {
"distance": 50,
"units": esriFeet
"Keep_only_closest_route_location": false
//'distance_field': true,
                //'zero_length_events': true,
                //'in_fields': true,
                //'m_direction_offsetting': true
gp.submitJob(params, processGP);
function processGP(jobInfo){
gp.getResultData(jobInfo.jobId, "LRM_DC_RM_MI1", renderResult);
function renderResult(result, message){
alert(result);
</script>
</head>
<body class="claro">
<div id="mapDiv"></div>
<div id="LatLng" >
Enter the lat/long:
</div>
</body>
</html>
RobertScheitlin__GISP
Terry,
  Here is a starting point for you. I have taken your code and re-coded using WAB widget coding conventions and added some code to add and remove the map click event based on if the widget is open or not. I personally would not use a map click event I would look at using the jimu drawbox dijit. I still don't know where to click in the map to get some actual results so I can help much there, but the GP is firing and running fine.
Terry,
  Lots of little syntax issues that a full fledged IDE would have caught.
<!DOCTYPE html>
<html>
<head>
      on iOS devices-->
  <style>
    html,
    body,
    #mapDiv {
      height: 100%;
      margin: 0;
      padding: 0;
      width: 100%;
    #info {
      bottom: 20px;
      color: #444;
      height: auto;
      font-family: arial;
      left: 20px;
      margin: 5px;
      padding: 10px;
      position: absolute;
      text-align: left;
      width: 200px;
      z-index: 40;
    .label {
      width: 4em;
  </style>
  <script>
    var map, gp;
    require(["dojo/dom",
        "dojo/_base/array",
        "dojo/promise/all",
        "dojo/json",
        "esri/map",
        "esri/domUtils",
        "esri/graphic",
        "esri/config",
      function (
        config, Request) {
          basemap: "topo",
          zoom: 15
          wkid: 102100
        function executeGP(run) {
          //You need to add the graphic to the features array
          var features = [graphic];
          //you had several param attributes that were suppose to be strings like json and esriFeet
          //You also had stuff in your params that your GP service was not expecting and your
          //Keep_only_closest_route_location was not the correct name.
          var params = {
            "f": "json",
            "outSR": 102100,
            "City_Centers": featureSet,
            "Search_Radius": {
              "distance": 50,
              "units": "esriFeet"
            "Keep_only_the_closest_route_location": false
          function processGP(jobInfo) {
          function renderResult(result, message) {
            console.info(result);
  </script>
</head>
  <div id="LatLng">Enter the lat/long:</div>
</body>
</html>
TerryGustafson
I have it open in brackets and note ++  but for some reason it does not see the syntax errors..
Strange. Anyway I had to add lines 132 and 133 because you did not have any matching (Paired) in your code. When you select a bracket or a curly brace in "Barckets" or Notepad++ it will highlight the matching one in the code if there is one.
Don't forget to mark this as answered.
TerryGustafson
Sorry Robert, I’m a slow learner.. So I must have something wrong with the “Search_Radius” as when I comment out
/**"Search_Radius": {
"distance": 50,
"units": "esriFeet"
"Keep_only_the_closest_route_location": false**/
it works fine. But with that code in there it does not return the map. When I zoom it close and click on the map it returns the correct data for that point.
Terry,
   I have no idea where I should be clicking to get any results. The code I provided (unchanged) does run the GP, but the returned features is always 0.
TerryGustafson
Huh, I can’t get it to run unless I remove that portion. Then if I zoom in really close and select a route it does return the correct values.. What browser are you running it in?
http://app.mdt.mt.gov/arcgis/rest/services/LRS/LocateFeaturesOnDCandRM/GPServer/Locate%20features%20along%20DC%20and%20RM/jobs/jd16fdc7086cf4c30999292ec2330e538/results/LRM_DC_RM_MI1?f=json&returnType=data
If I use the jsonLint it shows the route.
Terry,
   My preferred browser is FireFox.
TerryGustafson
I tried to convert the code into my own widget. When I open the widget I get a “create widget error:” I have tried finding what else I need to change. Here is a copy of my widget.js file for my custom widget.
What am I missing?
Terry,
   You need to get the Interactive Linter plugin for brackets by Miguel Casillo so that you can see all these problems (24 in total). I would also recommend the Beautify plugin by Drew Hamlett
